Most of the good stuff is gone but I still have these.
3.1L ported heads, upper and lower intake, and 56mm throttle body - $249
Chip and ECM. Great mid-range torque, like 89+ octane and No top speed governor. 92Z24 with manual. $100
J-car- Custom (one one pair in existence) Rear springs about 1" 1-1/2" lowering 800lbs, 550lb wheel rate, these are very stiff. Stock is about 165-175 lbs*in, Eibach Pro Set springs are 260-300 lbs*in, wheel rates are about 69% of the spring rates. Needless to say these are serious spring you need coil overs in the front with these, but your car will turn like never before esp with the big bar from below. - $75
26mm rear sway bar. - $75
Both for - $124
Workshop manual 1992 Cavalier/Z24 on CD, Is AllDATA, like AutoZone sells but on CD and no expiration date. - $20
92 Z24 strut tower brace. Not for sure what else it fits. - $25
3.1 MPFI upper intake. - $25
3.1 Exhaust manifold set - $50
Oil pump - $25
3.1 Coil pack with module, bracket and Magnecor wires - $50
Have some SFI parts left also. See the page below.
For picture and other parts http://www.zrracing.com/forsale.htm
Both for - $124
Oil pump - $25
