Turbo hybrid motor
  • For Sale : Turbo hybrid motor
    Quick back story: two weeks ago my timing chain packed it in and took my engine with it, so I need money badly.
    I do not know exactly what I have; I'll fix errors as I learn more. Since I now have no car and very occasional access to the shop where this is stored, pictures will take time. I don't have a problem piecing out the turbo stuff, but tearing into the engine for parts will take a long time for reasons stated above. I am not taking apart the heads to get at valves/springs/whatever. That is way more than I am even going to pretend to know how to do.
    Name a price on what you want and if it sounds reasonable I'll bite.
    This setup was Aaron's (loner666) previously.
    2003 3400 with all accessories
    Ported/polished 3500 heads
    Comp Cam Springs stock valves with 5 angle
    Custom length pushrods
    Turbo cam .533 lift @ 1.6 206 duration 108 lsa
    42 lb injectors
    3500 lower intake Gasket
    matched 3100 upper intake (matched to 3500 lower)
    TCE throttle body (65mm)
    Turbo setup:
    Turbo headers designed for 3x00/4t60e L-body
    Downpipe has two bungs (had two O2 sensors)
    System is heat wrapped to end of downpipe (Crossover and downpipe are wrapped and ceramic coated)
    Garrett 60 trim(.60ar compressor .53ar exhaust with a stage 3 wheel)-Turbo needs a new center section, it's in two pieces ATM
    No-name wastegate set at 12lbs
    Tial BOV
    Intercooler and piping designed for same car
    Piping is black, couplers are blue. Uses T bolt clamps.
    Inlet/outlet for intercooler is on right side
    I will do my best to check here every day, or you can get a quicker reaction by emailing aborchi2 at gmail dot com.
    Alan
    Timing belts/chains > me
    1992 Beretta GT
    If you decide to tear the engine down than lmk a price of the 3500 lower and 3500 heads. thanx
      PM sent on headers/intercooler.
        Price for fuel injectors?
        Pictures of the exhaust please.
          Pm me with how much you ask for the cammmmmm
          Originally posted by Mars
          Haha ^ Wrong Wheel Drive.
          No 60ºV6 at the moment
            Pictures of headers and downpipe.
            1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
              Sorry guys just getting a chance to check in. PM's replied to.
              Will have pics tomorrow.
              Injectors - $150 shipped?
              Cam - $200 shipped?
              Alan
              1992 Beretta GT
                Ill give you $200 if you include the pushrods
                  What would your asking price be for the turbo headers?
                    price for heads and lim?
                      Originally posted by lolwut View Post
                      Engine:
                      I don't know if it has upgraded valves and springs, but I'm pretty sure since it has... Comp Cam Springs stock valves with 5 angleCustom length pushrods
                      Turbo cam (do not know specifics, I believe it is similar to a WOT Tech street/strip turbo cam) .533 lift @ 1.6 206 duration 108 lsa42 lb injectors3500 lower intake Gasket matched3100 upper intake (matched to 3500 lower)
                      Turbo setup:
                      System is heat wrapped to end of downpipe (Crossover and downpipe are wrapped and ceramic coated)60 trim turbo (Garrett 60 trim(.60ar compressor .53ar exhaust with a stage 3 wheel)-Turbo needs a new center section, it's in two pieces ATM
                      No-name wastegate (12lbs, Forgot to change springs back to 6)Tial BOV
                      Fixed the info on some of the stuff. The heads, cam, lower intake, TB, pushrods came from WOT-TECH. The exhaust and intake work for the turbo was custom built by 60degreeInclusive (Forced Firebird) when first starting out. Injectors are a matched set from ZZP. Lower engine has around 43k. Upper has about 8k and turbo setup has about 6k and injectors have about 4k
                      Best 1/4mile ET - 12.9
                      Best 1/4mile MPH - 111
                      1997 Ford Ranger Splash
                      Daily Driver
                        Thank you very much, OP updated.
                        Working on getting back to everyone, sorry if I miss someone/get mixed up.
                        Edit: replied to everyone who posted in here/PM'd me via PM. Not trying to keep anything a secret just easier to track that I've gotten back to everyone that way.
                        Alan
                        1992 Beretta GT
                          im interested in the injectors and u dont happen to have a dhp or hp tuners tuning equipment do ya?
                          1996 Beretta
                          3100 SFI TURBO
                          13.1 @ 103 mph best in the 1/4 mile
                            Get in touch with Loner666, I don't know if he still has the tuning stuff or not.
                            Alan
                            1992 Beretta GT
                              My tuning stuff is sold
                              Daily Driver
