QuarterMaster 7.25" twin disk clutch/flywheel
  • For Sale : QuarterMaster 7.25" twin disk clutch/flywheel
    QuarterMaster 7.25" twin disk clutch and button flywheel setup
    I will be selling my fiero come next spring and I will not be switching back to this setup in the mean time so time to let this pretty much unattainable part go.
    This will bolt to any 60*v6, as far as which transmissions it will fit, that I am unsure of. I know for a fact that it fits in a 3.65 4 speed.
    -This is used.
    -It needs a new clutch cover (pressure plate) which is still available from QM, optional aluminum cover as an upgrade is also available.
    --clutch cover bad due to broken clutch fork and limping the car home
    -The disks/floaters should be fine still 20 miles maybe
    -Steel button flywheel,flywheel is currently neutral balance
    This is the clutch you NEED if you want to make big power and have the clutch hold it.
    if you have any questions just ask me, and hopefully I can answer. I will get some pictures up this weekend
    Whats included:
    button flywheel drilled for 60*v6 pattern
    2 clutch housings, twin and triple setup
    2 floaters
    1 floater/pressure plate contact
    3 cintered copper discs; 2 outsides and a middle for the triple setup
    1 clutch cover with bad fingers
    1 QM TOB, it is seized right now from the fork failure
    6 bolts/washers to bolt clutch cover to flywheel
    If I remember correctly, it costs $200 to have the clutch cover and the TOB rebuilt.
    Only pic I have ATM, this is from when it was just rebuilt
    Looking for $800 shipped
    Anyone?
      dropped the price a bit
