#19 Injectors
  • Wanted #19 Injectors
    Or whatever's similar to 17109826. I just need to keep the car running while I get one set or the other cleaned. I prefer the pre-2000 style connector (Bosch?).
    1995 Grand Am SE
    I've got a set of 25322180 Multec 2 injectors from a 00+ Malibu. $40 + shipping
      I've got set's from a couple L67's (SI and II),Fiero,TGP,LS1,and various Ford injector's.
      I'll check for you and see if I have any of that part number and what style plug it has.
      Pretty sure the TGP and Fiero are 17 or 19lb.
      I'll take $35 shipped for the TGP and Fiero injector's as is.
      If you want them sonic/pressure cleaned with my injector flush machine I can do $65 for the set shipped.
        Thanks for the offer, but I think those use a different connector.
        Let me know what numbers come up.
        1995 Grand Am SE
          ill have to look through my box of injectors by im fairly certain i have a set of 19# injectors.
          wont get down there till friday to look. let me know if that's good.
          99 Grand Am GT
          1357 cam 227 233 .050 dur
          515 515 lift 112 lsa
            They do. I know because of having to splice a set of them into the harness for this Achieva I'm working on.
              I'm not afraid to splice wires but it's excessive when I plan on using #36 injectors in the near future which use the same connections I have now.
              1995 Grand Am SE
                True dat... Can't say I blame you any there, really
                  I have a set of 90 model TGP injectors that are 19lb and should be same plug.
                  They are actually mounted in the flush machine now,not cleaned but I have checked spray pattern and leakdown on 3 of them.
                  Part number is 17086981 if you want to double check the cross reference.
                  I can post a pic for reference if needed.
                    It's been taken care of via PM's. Thanks for the offers guys!
                    1995 Grand Am SE
