Comp Cams Retainers
  • Wanted Comp Cams Retainers
    Anyone have a set of Comp Cams Retainers for the 26918 springs?
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    I have a set of slightly used steel retainers. $40 shipped to your door.
    Matt
      hey if youre getting rid of your stock retainers I'll take them off your hands if theyre for a 94+ 3.1/3.4
        I have some stock ones off of a 1999 3400 if you would like them.
