Crank & Connecting Rods
  • Wanted Crank & Connecting Rods
    Anyone have some for a 3400?
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    I have a crank that needs a polish, and some used 3400 rods still on the stock pistons.
      How would I polish it? And how much would you want for it?
        You take it to a machine shop and have them polish it.
          I have a crank with connecting rods/pistons out of a 3400 w/ 39,XXX miles. Had a machine shop check and polish the crank already but then decided to build a 3500 instead. Let me know.
            How much would you want for it?
              From his FS thread...
              Originally posted by 92cavquest View Post
              Cavalier
              95-99 cavalier brake calipers w/ hardware and semi-metallic pads $25
              95-05 cavalier 4t40e trans mount $10
              95-99 cavalier 3 speed trans mount $10
              95-99 cavalier 2.2 ohv front motor mount $10
              95-99 cavalier 2.2 ohv alternator $20
              95-02 cavalier radiator cover $5
              95-99 cavalier gauge cluster w/o tach $10
              95-99 cavalier 3 speed shifter assembly $10
              Grand Am
              4t45e side cover $10
              3400
              3400 front timing cover w/ water pump $15
              3400 oil pan $25
              .10 over crank bearings $25
              3400 windage tray $15
              3400 crank (polished and checked by machine shop)$40
              3400 pistons and connecting rods $45
              3400 block -hot tanked,honed, glyptal coated and machined oil passages, new cam bearings (prefer local pickup) $120
              3500
              3500 upper intake $70
              36# GTP injectors w/ pigtails $75
              3500 fuel injectors w/ harness $40
              3500 fuel rail $25
              3500 exhaust manifolds w/cats $40
              WOT-TECH stage 3 turbo cam 1617 grind $250
              custom pushrods for the cam above $100
              misc. other 3500 junk (let me know what you need)
                Thank you, sir. We'll get together and figure out the cheapest shipping option. What's your zip?
                    Good deal! Glad you found one that doesn't need work The one I have has a lot of miles.
                      there is a guy selling a forged 3500 crank on the alero forums if you dont end up buying this one, i dont know what modification you would have to do to get it to fit but it can be done i think.
                      2002 Pontiac Grand AM GT K&N WAI, Pacesetter 2.5' piping/SLP loudmouth exhaust, Magnaflow High Flo Cat
                      2006 Pontiac GTO 6.0/Iron 370, Kooks 1 7/8 Longtube headers, Mahle forged pistons, Scat H-beam forged rods, Custom Cammotion boost cam, Magnaflow Catback exhaust.
                      Coming soon: Trickflow 235 heads & Magnacharger TVS 2300
