3.4 DOHC, Fiero, random car parts. BEST OFFER!!
  • #31
    I have any of the 3.4 DOHC valvecovers. I don't have any front side manifolds that I am not using. Let me know what you need for valvecovers.
    3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
    1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
    • #32
      BUMP!
      • #33
        I know this is old, but I'll try my luck anyway, looking for an EGR Tube 93 3.4 Dohc
        • #34
          info/pics/price on lower/custom intake?
          • #35
            Any DOHC parts left?
            • #36
              do you have a 85 pontiac fiero 2.8 gas tank?
              Originally posted by fieromadman View Post
              Prices are best offer, but if you lowball too much I wont sell.
              Here is a list of stuff that I have for sale:
              *3.4 DOHC/TDC STUFF:*
              6 Stock 95 DOHC injectors (the less noisy ones, worked great when pulled, been stored with caps on them since) They are rated at 23# / hr
              Stock 95 MAF for a dohc
              Three sets of cylinder heads. One a 91-95 used, disassembled, slightly ported (80% done, will finish for a price, from the .nl build thread). Another pair of 95's brand new off a crate motor, slightly ported as well, these will need more work to finish and frankly I'm not willing. Then a set of 97 heads still on my 0 Mile crate motor.
              Set of stock assembled 91-95 3.4 DOHC cylinder heads
              Two sets of DOHC cams. One pulled from the current engine in my Fiero upon installing the aftermarket cams. Perfect candidate for a re-grind. Another set out of the 96 or 97 crate motor. Zero miles.
              One 91-95 lower intake with the start of a custom upper intake.
              3.4 DOHC lift bracket/dogbone bracket that attaches to the front cyl head
              egr block off plate for 91-95 intake manifolds for the 3.4 dohc
              black painted valve cover for rear of 3.4 dohc engine
              One gloss black painted upper intake off a 91-95 DOHC
              Valve covers for ANY year DOHC. (minus the front one for a 96-97)
              I'd consider selling the 96-97 zero mile crate motor whole for the right price.
              94-95 ECU (EXCELLENT CONDITION) Memcals available too
              Rear 91-95 DOHC exhaust manifold
              3.4 DOHC stock crank pulley
              3.4 DOHC engine sensors. Some new, some used. All tested. Ask and you will probably recieve.
              91-95 intake manifold style 3.4 DOHC coolant neck
              Custom 3.4 DOHC to Fiero dogbone mount. This piece was off my car untill I did the 96-97 intake manifold swap. Works great with the 91-95 manifolds.
              *FIERO STUFF:*
              Fiero emissions canister for 2.8 that sits by intake canister
              Gas tank vapor canister. (mounts in passenger side rear quarter panel) Perfect condition
              2.8 Valve covers
              Stock V6 Fiero dogbones (2)
              2.8 Injector harness
              fiero interior door lock tabs that go by the door handle
              Fiero v6 cruise control cable
              2.8 Coolant tube that runs in front of the engine (prone to cracking or rusting or whatever) This one is CLEAN, off a southern car!
              A couple of getrags... Parts mainly. (one a stock Fiero unit missing the speedo gear on the diff and speed sensor with a kinda bad case, the other a 93 vintage FWD tranny with a brand new quad 4 bellhousing). With a few parts here and there (speedo gear and fiero speed sensor) you could build a strong getrag.
              Fiero V6 engine bay alternator and coil aluminum blower tubes
              Fiero V6 lower intake manifold
              *RANDOM CAR PARTS:*
              Fiero and 3.4 DOHC wire connectors. I have about 4 wiring harnesses cut up, some fiero, some 3.4. ALOT of connectors left to replace bad ones.
              AC lines for a Monte Carlo z34
              Greddy Turbo timer
              2G DSM Energy Suspension engine mount inserts
              EVO 8&9 560cc Injectors (same as DSM injectors, just bigger)
              Brackets for holding a conventional style one farad capacitor. Diamond plated aluminum. HARD TO FIND THESE SOLD SEPERATE!
              Front brake rotors, calipers, and pads with approximatley 1000 miles on them (except for calipers, those have 80,000) for a 95 monte carlo z34.
              4t60e axels out of a 1995 monte carlo z34
              I have more. I will post up as I can remember. Pictures available upon request. Live two blocks away from UPS store, and 5 mins from a post office, so shipping is quick and easy. Most parts have been packaged for years already. HA.
              Also selling a couple of non Fiero/non car related things:
              Nitro RC car. It's a Hot Bodies (HPI) Tornado. TONS of new parts, TONS of spare parts. Aftermarket EPIC .18 engine. Thing FLIES! Runs/drives great. Out grew the hobby. Lots invested, will let go cheap.
              Nitro RC boat. It's powered by an airplane engine, so it's more of a fan boat. Goes 40+, Powered by an O.S. MAX .40 Needs a few things. Over 300 invested will let go CHEAP!
              Piranha paintball gun. WELL MODDED. Electronic trigger, low pressure changer, highest rated barrel at the time, drop forward, quick trigger, expansion chamber, two tanks, all accessories and stock parts included. Really needs and electronic hopper. Way too much invested, will let go for cheap. Well taken care of.
              Samsung Upstage cell phone for sprint users. Includes EVERYTHING that I originally got it with. Works great. A few minor cosmetic issues but nothing major. Will sell for REAL cheap.
              Will consider trades for any items as well
              Again ALL parts are best offer
              • #37
                I've bought parts from this guy. Good guy to work with.
                • #38
                  Any chance the Fiero Getrag is still available?
                  • #39
                    WHAT ARE YOU LOOKING TO GET OUT OF THE getrags GETRAGS SRE THEY 5 SP I AM PUTTING A 3.4 DOHC IN MY FIERO HAD TO GO THE CHEAPER SWAP DON`T HAVE THE MONEY FOR A SBC SWAP ADAPTERS COST $$$$. HAVE A 4 SP NOW WITH THE 4.13 FINIAL
                    • #40
                      I need the front and rear mount brackets which attach the transmission to the mounts. I do not need the mounts which are bolted to the cradle.
                      • #41
                        lots of heads, Do you have any spare pistons? 91-95 dohc.. with rod, without? lol
                        • #42
                          1 year old thread... not sure if you will get a responce..
                          Shane "RedZMonte"
                          1992 Lumina Z34-VIRGIN (RIP)
                          1992 L67 Lumina Z34 (SOLD)
                          1990 Turbo Grand Prix (SOLD)
                          • #43
                            yikes. i am kind of feeling sorry that i ran into this only now. some of the parts here i have been searching for online for weeks. looks like you can't just ask around but you also gotta hit the forums.
                            __________________________________________
                            Facel Vega Parts
