1990 3.1 V-6 performance motor. Heads ported and polished Fresh valves, guides,springs. stage one comp cam. underdrive pulleys. remanufactured block. everything is new. water pump, timing chain, alternator and starter. various sensors. this is a turnkey motor. also have headers, oversized downpipe, collector and crossover. comes with complete Fiero exhaust and new flowmaster muffler. Has Accel ignition coils, MSD dis 4 box, Taylor wires and AC Delco Rapid fire spark plugs. I have 1000.00 in heads, 1000.00 reman block, 1000.oo in extras.Accel fuel injectors 2lbs overstock. Also to really make this rip I have 125c transmission complete rebuild 2800 stall, 3:65 gear ratio, shift kit, fresh rebuild. This is coupled with a 85 swing arm and comes loaded with polyurethane. Also have modified CV axle shafts to handle the higher horsepower and torque. I also have ECM and wiring harness for a 90 barretta coupled to fit Fiero chassis. My loss is your gain 1300.oo takes all. headers are an extra 200.oo not seperating except for headers. You can sell everthing to Fiero guy that you don't want and make some money back
3.1 V-6 90 barretta modified
3.1 V-6
please respond to barry.burd@hotmail.com
I am not sure what the shipping would be. I wouldn't know how to ship.
I originally had it in a fiero. I couldn't get the motor to stop the headers from glowing red hot. In the process of working through some diagnosis problems I realized the cam was to big and the computer needed to be remapped. When I purchased the cam I was told this was not necessary. A result of that was a burnt valve. I immediately had the heads pulled and went with a stage one cam. I had the cam degreed and the heads redone.
