WTB engine harness
  • WTB engine harness
    Looking for a fwd 2.8 or 3.1 engine harness for my 3.4/3500 hybrid. Gonna be running a 7727 ecm. Thanks!
    3.1 has a '7730 ECM (MAP), the 2.8 ECM you listed is MAF, just be aware that there are 2 different harnesses.
    I would suggest using a '7730 and there are plenty of harnesses for V8's on ebay for them.
      too bad you dont need an OBD2 L-body engine harness, i got one from when i was gonna do the swap on the Z26.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        I thought the 7727 was simply the weatherproof version of the 7730?
          the 7727 uses 4 plugs compared to the 7730 using 3. they can be used in place of each other. uses the same tunes, just different connections
