Sensor Pigtails
  • For Sale : Sensor Pigtails
    since i don't need the engine harness for the 92 GP anymore i cut it up into usable lengths. i tried to get at least a foot of wiring for each one, some got more, some i had to give it 2", then solder and heatshrink on an extension of wire. most if not all of the sensor connections are here, and i also have a IAT sensor. the only things i can think of that are missing is that i only have 3 or 4 fuel injector connectors, 2 of them i had to extend, and i'm not sure where the third and possibly fourth one is at the moment...
    price: IDK a dollar each + shipping, OBO?
    i'm not really looking to make money off of them, but i don't need them and i'm sure someone else does...
    I need the connectors for IAC, MAP and Charcoal Canister.
    Give me a total cost shipped to 06473. Paypal work?
    Thanks,
    John
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
      IAC
      MAP
      Canister Purge
      do all of these look right?
      and i can't do paypal, sorry, my account is locked from someone trying to get into it and i can't get ahold of the info necessary to unlock it.
        yes, those look correct. I'm assuming none of the ones your are selling are broken? The securing tabs on mine have snapped off.
        I can send you a check, PM me your info and price.
        1994 Corvette
        LT1/ZF6
        3.7/42RLE
          well count out the MAP sensor and the cannister purge
          MAP: tab is broken off
          Cannister: can't find it.
          the IAC still has a good tab and seal but i'll have to extend the wiring.
            ok, nevermind then.
            1994 Corvette
            LT1/ZF6
            3.7/42RLE
              The MAP's always break off. The green plastic is brittle compared to the black I guess.
                do you have anything for the pre cat o2 sensor??
                93 Firebird 3.4
                  Did those have the 3 wire heated o2 sensors in them? If so I'll send ya $5 for the plug and that should cover all shipping.
                  87 3.4 4x4 blazer
                    GRAVE DIGGERS!
                    pre-cat O2? i can't think of any 60V6 applications that were OBD1/1.5 that actually used a post-cat sensor... if you're talking about the 'bird, i think that used just regular 1 wire O2s? i'll have to look to see if i still have it...
                    and no, the early LQ1s did not have a heated O2, and i think we went directly from a 1 wire to a 4 wire... though the actual connector may be a standard one, i really don't know.
