My motor and related parts
  • For Sale : My motor and related parts
    Sad day but the time has come for me to part with my motor and the related parts. Due to the transmission issues Ive had with this car, the lack of funds to fix said issues, and a big move north soon are forcing me to sell. I am keeping the body and interior. Everything else can go. Motor, suspension (need to work a deal on that as I may need a stock setup for transport) engine harness, turbo exhaust piping.
    Right now Im getting interest together. Most is still in car but hoping to get out very soon. If someone wants something before I get it out then I can get off my ass and start working again to get it out sooner.
    -Motor specs can be seen in my sig. Heads will come with comp cam springs and ARP head studs
    -Suspension is KYB/Eibach combo. Less then 3k on setup (except adjustable rear air shocks)
    -Engine harness is a modified OBD2 harness from a 96 L body. Made to work with factory 94-95 OBD1.5 L body harness. No PCM. No idea what other cars it will work on other then 94-95 Corsica and Beretta
    -Turbo exhaust consist of custom made headers, crossover, and downpipe. I can not confirm if this will be a perfect fit to any other car other then 3100/4t60e L-Bodies. Should fit in others but may require some work. Crossover and downpipe are ceramic coated and wrapped. Headers are just wrapped.
    -Im keeping the BOV, intercooler, and turbo. Tuner and injectors are pending sale to fellow L-body owner. Meth Injection is possibly pending sale as well
    -All other parts avaliable. Radiator, maybe subframe, Strut tower bar, MRZ shock tower bar.
    Let me know what you want either here or PM and Ill let you know if its avaliable and what I would like for it. All prices will be fair considering what I have put into everything. If its not body, interior, or needed to transport the car it NEEDS TO GO. The less I have to take north the better for when my new project begins. Please spare me the "Keep it and fix the problems" speaches. I would love to make it better as is but I badly need money right now and I have something better in mind for the car.
    The current setup ran a 12.9 @ 106 on heavy 17" drag radial on less then 10psi and using washer fluid for injection. Motor has seen a 111mph pass on small 15" tires but had no traction at all. I feel with around 12psi, light weight wheels, slicks, and better meth mixture its capable of seeing 11s
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
    Very interrested in the heads! it 3500 heads? If so I have dibs.
    Do you have the LIM and UIM??
    Mike 60degree addict.
      Only has the LIM IIRC... he has a 3100 large bore upper intake on that matched to the 3500 lower.
        ^ He is correct. I just sold my 3400 upper that matched. Never had a 3500 upper
        Daily Driver
          Iwill find another Upper.
            PM sent on turbo exhaust kit
              if he doesnt want the turbo stuff, i might be interested, id need pics of the crossover/turbo mount tho...
              actually, id like pics either way
                Best pic I have
                Daily Driver
                  is that a T where the Y joins?
                    Where the Y joins is where the wastegate is underneath
                    Daily Driver
                      Keeping bottom end, cam, pushrods,valve springs, suspension and possibly the turbo setup due to lack of people liking my prices. Ill just take the car running up north and terrorize a new track till I have money to redo the car. Heads still available. Ill work a good deal with you if you have a set of stock ones to trade me. Shock bar and strut bar still for sale as well
                      People that have asked about the turbo setup will still be given the chance but no more people for now
                      Daily Driver
                        Why yes it is! When you build a complete turbo kit in 48hrs in a tight engine bay, not everything can be perfect
                        Aaron, kinda glad you might be holding on the it, even if it means no money for you...
                        If you are looking to get some stock stuff, I'll trade you stock (or yellow) springs for the Comps with a little cash. Hit me up with a text or PM
