96 3.4 DOHC Cam Gears
  • Wanted 96 3.4 DOHC Cam Gears
    I busted 2 cam gears on my 96 MC. I have not been able to locate any around Ft. Worth any info would be appreciated.
    Thanks, Clint
    How did they break?
      They were way to tight so I twisted my holding tool. Then did what any genious would do & used a pipe wrench before I found out the pulleys were discontinued.
        Also under that bolt is a typ of lock washer What you should had done is turned the cam 90deg and put an adjustable wrench on the cam.
          hey im in grapevine,tx. i think a gotta couple foe ya. holla back
            Hi Sonyman I sent you an email but not sure if you got it it doesn't show up on my sent folder.
            Thanks, Clint
              I have a couple cogs currently. PM sent.
