wtb 90-94 3.4 lower intake
  • Wanted wtb 90-94 3.4 lower intake
    I f'ed up my lower intake on my 92 z34 and need a new one. I got one from a 95 monte, it looks the same but it doesn't want to idle for shit and in my manual it says that a 95 lower has a different torque spec than the 90-94. Just want to try to eliminate that as a problem. I found a place that has one but they want $110 for it shipped to my door and that's kinda silly. So if anyone has one laying around I'd gladly take it off your hands
    91-95 LIM should all be identical. 96/7 are the different ones. Break out the carb spray and make sure you don't have a gasket leak present. If the idle changes when you spray it on gasket surfaces, you found the area of your leak. Also if you didn't change the gaskets between the lower and the head, do those too, the design on them sucks, and is very prone to leaking.
      well that's good to know at least, I can kinda feel a breeze around the area of my map sensor, thought it might just be from the pulleys as well. I'll go try the carb spray though. thanks
