*Wanted! 96 3.29 or 3.05 diff
  • *Wanted! 96 3.29 or 3.05 diff
    For a 96+ 4t60e, Either ratio, doesn't matter. If possible I would like the spiders to be checked for galling against the center pin, I have a set I could use in a pinch but a full usable diff would be better.
    PM me if you have something!
    BUMP
    The diff's I'm looking for came in these cars
    96
    6CUW 2.4 N-Body 3.05
    6WFW 3.1 L-Body 3.29
    6BSW 3.1 N-Body 3.29
    6PKW 3.4 U-Van 3.29
    6CAW 3800 G-Body 3.05
    97
    7ASW 3.1L N-Body 3.29
    7BSW 3800 W-Body 3.05
    Other trans codes dont know body style
    7AHW 3.29
    7AWW 3.29
    7CUW 3.05
    7YAW 3.29
    98
    8AHW 3.29
    8BSW 3.1L N-Body 3.29
    8CUW 3.05
    8DKW 3.29
    99
    9AHW 3.29 < only 99 trans listed in my book, I'm not sure if there were more.
    A 3.29 would get me a 3.68 FDR to play with; it wont be the one that gets the LSD treatment but I would be able to see what it runs at
      So a '95 is different huh? I've got a 3.29 unit from a 95 U-van w/3800 that I'll likely never use.
        95 is a reverse cut, its fine pitch but they changed the direction of it and then in 96 they went back to the 94 direction but kept the fine pitch... so the ratios are the same just pointing in the wrong direction.
        Can be closed, I purchased a FD setup from e-bay for a 96.
