95 4t60e F/s
  • 95 4t60e F/s
    Perfect/complete trans and converter from my 95 Lumina 3100. I had to replace this trans with a 4T65E, as I am converting the engine to a 3.4 DOHC. The 97 wiriing/PCM is not compatible with the 4T60E.
    Fluid is clean, and I gave it a curosry internal inspection...chain is tight, differential is perfect, busghings are good, no crap in pan....etc.
    I'm near Chicago.....as with the engine, best offer gets it
    Doh!
    The trans has 50K since it was rebuilt....all highway. The engine has different mileage for different parts The heads and bores are around 80K, while the oil pump, is about 50K and the cam is new The rest of the parts....at most (valve covers, front cover, intake, etc....) have 285K on them
    Larry
