WTB 3400 uper and lower intake
  • WTB 3400 uper and lower intake
    looking for a stock 3400 or 3100 "big bore" intake
    How much are you looking to spend. I have a upper and lower intake off a 99 3100.
    95 Beretta- Lg8 Daily Driver
      I've got a upper and lower from an 05 3400 motor, fuel rail and injectors.
      $150 for everything shipped in the U.S.
      G6 GTP 3900 6spd Coupe
        intakes
        are the intakes stock or worked done to them
          If you're asking me well NO, they are stock no work done to them.
          STOCK Upper/Lower intakes, fuel rail w/injectors, and the TB.
          I was going to do the 3400 top end swap on a old Beretta I had but change of plans. Sold heads locally awhile back.
            Mine are stock. I painted the upper intake red, but I cant strip that off for you very easily.
            Shoot me an offer of what there worth to you.
              I have a large bore 3400 upper and a large bore lower.
              THe lower is brand new never installed but did do a bit of gasket matching on. The upper is used but good condition. Says 3400 on it
              The upper I might have touched up a bit to clean up the flash, and the lower I gasket matched the upper part of the middle intake where it meets the upper intake.
              I also have a fuel rail too if needed. I can take pics of everything
              Shoot me an offer.
              Shaun41178@hotmail.com
                Are those 99 3100 intakes the big bore ones? I assume so just curious as it seems the big bore 3100 in 99 is kind of rare.
                  I never compared it to my current 95 topend. But its off a 99 and has the smooth top with the raised numbers.
                  How can I confirm that its a big port?
