FS: 3100 large port parts (Cheap!)
  • FS: 3100 large port parts (Cheap!)
    I have the following items I need to sell. They are from a '00+ 3100 (large port). All items will be washed/degreased before shipping.
    2 3100 large port plenums. One has the casting flash removed from the exterior and I started to polish it. You can see from the pictures that I stopped half way through. The other is untouched, as you can also see. $30 each or $50 takes both.
    1 Throttle body. $20
    1 lower intake (I'll leave the EGR on it). $50
    1 set of heads. I will also include the valves, springs, and rocker arms. They were just removed in these photos. $80
    6 injectors, injector wire harness, and fuel rail. $60
    Or if you want it all, $230 takes it.
    $230 shipped?
      Let me know what your zip code is a I'll see what shipping would cost. I'm sure we can work something out (if you are serious and not just a tire-kicker! )
        I would like the heads. How much would it be total? Zip code is 21740
          that would work out good, because I have a set of 3400 heads and just need the manifolds and TB
          My zip is 33065
          EDIT: Do the heads come with the valvetrain parts, valves etc?
            Yes, the heads come with valves, springs, rocker arms, etc.
            Forced, I will give you first dibs on the whole thing since you were first to ask.
              if noone else gets them i'll take the heads
                Take Paypal?
                  damn John, you suck you ever gonna let me get a set of heads so i can get this thing started? lol
                  guess that inventory is growing pretty large by now huh?
                    Yep. I needed the UIM's and TB to complete the 3500 4thgen f-body swaps I'm putting together.
                    After these come in, they'll be about 5 sets of gen3 heads (4 complete top ends), 2 iron top ends, a 3.1 block, 3.4 block, and a 3500 block.
                    I thought you were going with a 3500 top? If so, I can grab another 3500 to part out for you . I'm going to take a 3500 crank and see what it's going to cost to make a stroker kit
                      Going to Busch Gardens for the weekend, if I can get to a connection between now and then, I'll send it - otherwise it will be Mon.
                        i found a shop that would do it for $250-400 depending on the grind.... im also planning to use 5.7 sbc rods so that'll save money aswell, hell, if i was doing this on the cheap im sure i could make a 3.65 or 3.7L 7k rpm capable short block for under $1500, its really not as bad as everyone thinks
                        im actually thinking about going with 3400 heads ported for boost and a 3500 UIM for now because its currently a stronger setup from what ive heard, then maybe in a year or so the 3500 heads might be on top and i'll upgrade... basically im trying to get whatever i can right now though and build from there, either way i dont see this engine having any problems making power
                        btw, not much money at hand currently but if you could offer the same kind of deal that your getting here i would deffinetly be interested
                          Stroke the 3900 instead
                            I would for my next motor if they weren't so scarce/expensive.
                            Stroked/turbo'd 3500 RWD FTW.
                              There's no way you'll let me get these heads?
