3500 parts and cpl 3400
  • 3500 parts and cpl 3400
    3400/3500 egr 30 for either shipped
    3500 o2 sensor 30 shipped
    3500 short block dont want to break into it unless most or a big item is sold ( crank and/or pistons) has bout 35-40k on it
    3500 knock sensors 25 shipped for (2)
    3500 uim bolts 15 shipped
    3500 injectors w/ rail 45 shipped
    3400 coolant rail 20 shipped runs in frt of the motor
    3500 tb 20 shipped
    flywheel bolts 10 shipped
    may have others i will look and post up 2morrow
    BUMP BUMP
      does the 3500 have a forged crank?
        not sure have to ask ben or if some1 else reads this please chime in
          No, it does not, but alot of them have steel cranks, which will be stronger than the standard cast cranks. Post the numbers on the snout of the crank and we can determine if it is a steel unit or not.
            I'll take the 3500 UIM bolts... if you still have 'em.
            -RUSH
              bump
                is the short block a steel crank varient? i might be interested....
                  ^^^ what do u mean ? its a complete lowerend with timing cover and im willin to meet u at the pa/ny borderif u would like also for the price of gas and ill let the lower end go for 140 if ur interested
                    is the crank pulley off? can you list the numbers off the end of the crank?
                      ill have to check it tommorw i never removed the oil pan i just took the top end off for my build
                        not the oil pan, just the crank pulley that sits on the end
                          if its 8 digit this is the # i came up with 10343247 lmk if this helps and i have #s of the journals also if that helps also
                            actually its the 4 digit, do you have any way of taking a picture? sorry but its pretty criticle for my build plans
