proper turbo for a hybrid
  • #16
    Originally posted by Shaun41178
    hahhaahha boost at idle? What a joke. Talk about nothing but hot air. IHI is a heat generator for a v6 application of our motor sizes. And tell me where you are going to find a good IHI turbo off of a T bird that is 18 years old? Why the hell do you think the person is putting on a T3 in its place? Cause its garbage.
    Ouch, shaun!! IF you do your homework (and not bully a dork into doing it for you) you will find more than surface scratch. To help you on your way check these eBay auctions:
    Item number: 280022168748 (IHI that will work REAL good on your car)
    Item number: 120025392090 (T3)
    Item number: 120025393622 (T3)
    Item number: 130020903301 (IHI)
    Item number: 220021776792
    There are plenty more, just look.
    Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
    • #17
      t-birds had a t3 turbo aswell
      i've had one, but put it on my 4 cyclinder car
      • #18
        Yea, my cougar had a T3 as well. Was a good turbo. I was bragging on the IHI because they can be had for cheap and come on early (the T3's come on around ~1500rpm, 600rpm higher than the IHI) and arent as likey to blow a motor when tuned properly. The IHI maxes out @ 15psi and the T3 pushes 25++psi STOCK (I know, I turned my T3 up that high and have heard of T3's pushing 30psi) which is way more than ness. to blow a 3x00. In this case IHI is more proper.
        • #19
          the thing is tho so what if it could push 25+psi but how efficent is it at that psi, thats the real thing u gotta look for.
          i'd take a larger turbo and run 6psi compared to the 12+ on a smaller one and have less heat and push the same cfm if not more.
          lag isn't always bad especially on a 660 n/a they have probs hooking up i'd like my boost to come in at 2500 and pull all the way to redline
          perfect for street
