3 bar map sensor
  • 3 bar map sensor
    do tgp's or 3.1T have a 3 bar map sensor or is it a two bar ?
    It was a TWICE
    If you buy one off of someone...Look for either one of thise numbers: 886, 012, 539, 609..being stamped on the top of the map sensor...where the electrical plug plugs into. Next to thiese numbers are the 4 digit date code. Fist number is the year..then the next 3 are the day of the year.
    So one of mine read out 886 6218. 886 indicates its a two bar...then 6 means it was made in 86 and then 218...218th day of the year. (snaged from sunbird turbo)
    Another one of mine has 012 8032. 012 2bar...8 year '88 and then 032 day of the year. (snaged from my doner TGP)
    If you see 466...that's the wrong number...its on all map sensors.
    All 1bar have 039, 883, 460.
    There only one 3bar map sensor that I know of...It has 749 embeded on it.
