Originally posted by ericjon262
View Post
The GT35 should be a great size for the 3500. Have you consulted a turbo compressor map yet? That will answer all your turbo sizing questions. Then you can use the data from that map to build the headers to fit your flow amounts just right. There are formulas out there that will give you a precise primary diameter/length according to flow, displacement, peak power rpm, boost ratio, etc.
Originally posted by bigcheese
View Post
IMHO, I would try the GT35 first. Smaller turbos tend to spool very nice. If anything, get the tuning done first, this way if the tuner screws up or something goes wrong you're only wrecking a cheap turbo.
