New (L32) 2 bar map sensor compatible?
  • New (L32) 2 bar map sensor compatible?
    Just wondering if the new map sensors used in the L32 series 3 3800 are interchangeable with the old 2 bar map sensors, on lets say an OBD1 system. It looks to me like they are physically the same as the 3500 map sensor, so anyone running a 3500 turbo could use them in the stock location.
    the ecu will not understand anything over 1 bar. if you swap it you will have to change the ECU code to 2bar as well..
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      I didn't ask for turbo tuning 101, I'm quite aware of what needs to be changed within the prom. All I want to know is if the new style sensor is backwards compatible with the older ecus. For awhile people weren't sure if the 3500's stock map sensor could be used on an obd1 system, and it was later proven that they work just fine. So I want to know if the same holds true with the 2 bar maps.
        Am I going to need that also? lol
          I'd say it will work if it is indeed a 2 bar.
          The supercharged cobalts that had that style had two sensors, IIRC. The MAP was less than 2bar, like 1.5, but the "baro sensor" was 2bar... There was a thread a while back I believe on an LS1 forum since the LS1 uses the same style as the 3500 and they were looking for that style in 2bar.
          It should work fine.
            Ok, well that explains why when I search the partnumber it sometimes comes up as a "baro sensor" and when you search for a Cobalt SS, there are 2 sensors listed.
              Well, depending on what ecm you plan on running in the car. You will need some sort of 2 bar map sensor, the reason I was interested in this one is that it fits right into the 3500 upper manifold.
