Just checking interest at this point...
Kit off of a 1995 Z34... will work with any 1991-1995 DOHC.
Im getting ready to redo all my piping on my turbo kit. Im removing the stock log manifolds, x-over and downpipe.. I wanted to check to see if there is any interest in my old parts. it would literally be a bolt on setup for anyone looking to go turbo. My new setup will be tubular and stainless all mandrel bent. I am at 5800ft elevation so im trying to increase my spool up time is the only reason im considering replacing the current setup.. It spools good now but at this elevation it does have some lag. At sea level or close to you will not have any spooling issues...
X-over is 2.25" alluminized w/ T4 Flange, downpipe is 2.5" alluminized, and rear manifold is a stock front log. all you would need is a Wastegate, turbo, oil lines and boost piping which are all off the shelf bolt on parts. everything im taking off is the expencive parts all custom.
Here is a pic of everything installed:
S
S
