I might be buying a 1981 Isuzu I-Mark LS with a 1.8L Diesel engine today. I'm pretty sure it's a n/a engine, and assuming it's mechanical injection. What are the considerations for adding a turbo to boost the efficiency?
Non-60V6: Adding Turbo to n/a 4-cyl Diesel
'71 Opel Kadett Wagon - 1.9L CIH w/ Weber DGV 32/36, in bitsTags: None
Not today. Maybe tomorrow.'98 Volvo V90 - Ford 5.0 swap in progress
You're going to need to figure out a way to control the fuel delivery system. I would think it would be sorta worse for economy purposes unless you can fine tune it for all aspects of driveability situations. So I wouldn't go and add boost unless you just want more power while risking your mpg some.
I am not very familiar with the Isuzu's, but if the 1.8 is anything like the German 1.8 gas engines with mechanical fuel delivery (1975-1981) then you will for sure see a drop in mpg and not much gain for power per $.Lifting my front wheels, one jack at a time.
It's a Japanese diesel, so I don't imagine it's too much like a German petrol engine of the same displacement. :P I get what you're staying though. I just don't know what internal differences there are in a n/a diesel vs a turbo diesel. Different compression ratios, injector flow, etc.
I mean, there's a reason nearly all diesels are turbo'd. They work better that way. We'll see how it drives as-is. I'm sure it'll be fine, but I bet it could be better. I wouldn't be driving this car for performance though. #1 is just because of the collectablility, #2 would be the mileage/efficiency.
I'm still planning to check it out tomorrow.'98 Volvo V90 - Ford 5.0 swap in progress
I just bought this car, and I call it "Captain Slow". Freaking neat little car though. If I can turbo it, I'd like to. Wonder if I might be able to strip the turbo stuff off a VW 1.8L diesel and rig it onto this one. I think I'm going to keep this little car, it's awesome!'98 Volvo V90 - Ford 5.0 swap in progress
I belive those have too high compression that if you turbo it, you'll need to run low boost like 3-5psi like the GM Duramax. You'll also need to retard the injection pump a tad. You'll need a dial guage for that though. Or just mark where its at and pull back on the pump a hair at a time. Thats if you pump can ajust for altitude and boost. Check the diesel forums.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
I don't even know if it's electronic or mechanical injection yet. It would be cool if I could turbo it, but I might be stuck.'98 Volvo V90 - Ford 5.0 swap in progress
51 horsepower
72ft/lb torque
21.5:1 compression.
I'll probably leave it as-is. More power would be cool, but that's not what this car is for.
Maybe I'll try to find another I-Mark (petrol) and swap it for a 60ºV6, same frame as the Chevette so I know it's been done.'98 Volvo V90 - Ford 5.0 swap in progress
Ok, so there is a guy out there that has turbo'd his I-Mark Diesel. Says he runs 5-8psi with good results.
So, how do I pick a turbo to deliver that much boost? There is a place in Portland that could probably fab a turbo header for me. I'd plan on intercooling, and maybe propane injection.'98 Volvo V90 - Ford 5.0 swap in progress
Originally posted by Canyonero View PostOk, so there is a guy out there that has turbo'd his I-Mark Diesel. Says he runs 5-8psi with good results.
You will regulate the amount of boost with your wastegate and boost controller. You need to pick a turbo that will be efficient on the engine you have.
