Need some input on turbo
  • Need some input on turbo
    Hey all.. I have just got to have a turbo :P I was curious if a turbo charger from a mid 80's dodge would work... I am not asking for alot of boost,mainly want the sound,and little extra power,I wasnt wanting to push anything more that 3~5 psi..
    I was curious if obd1.5 would put up with that small amount of boost,untill I get my obdII stuff in? I've rebuilt alot of engines,but Never messed with turbos,I am not even sure how to hook one up,Gotta learn fast:P Is there a how to on installing a trubo??
    Thanks
    Russ
    Sawzall, and a bottle of nitrous.
      Depends on what turbo it is its eather a T2 or a T3 and way too small. you would choke your engine! keep in mind it would be off a 2.2L or a 2.4L 4cyl. you need a big T3. reasurch the 1989-90 Trubo Grand Prix (TGP) design. its not hard if you have the right equipment/resources.
      S
      Shane "RedZMonte"
      1992 Lumina Z34-VIRGIN (RIP)
      1992 L67 Lumina Z34 (SOLD)
      1990 Turbo Grand Prix (SOLD)
        And wait until you can tune. Any amount of boost needs a way to adjust for it.
          5psi boost you should be fine w/ a walbro 255lph HP pump and FMU. i ran mine like that for over a year before my OBDII swap and 42# injectors.
          Shane "RedZMonte"
            hey guys,is there a certain trim size I am looking for??
              Hi I would get a .60/.63 t3 and call it done.
                What kind of numbers did you run? Ever dyno it? I also have a 95GP
                  on one of my runs i had 260hp and 249tq on OBDI/FMU and 5psi. OBDII and 42.5# injectors 289.9hp and i think it was 270tq on 7psi.
                  S
                  Shane "RedZMonte"
                    S
                    What turbo were you running?
                      Turbonetics T04E Super60
                      1995 Monte Carlo Z34 T04E Turbo264.9 HP / 249.2
                      I ran a 14.3@101mph in denver (bandimere Speedway 5800ft.). stock they run HIGH 16 low 17's in the 1/4.
                      S
                      Shane "RedZMonte"
                        TimG has the same setup as me and on 10psi he put down i think 325hp and 350tq.
                        Shane "RedZMonte"
                          Thanks for the link but I don't think I could make as much as you at the same psi on a 3100.
                            My old TGP with a downpipe and intake i mustered up 215hp/tq on stock boost. and the 3100 has better heads and intake, ect... And i had a bad O2 sensor so i was RICH RICH RICH... so you should be probibly 220-230hp on low boost and a 3100.
                            S
                            Shane "RedZMonte"
