3.4 DOHC Boost???
  • 3.4 DOHC Boost???
    im eventually looking into boosting my 3.4 i have a cutlass and it seems that theres not much space under there for money to power and reliability wise what would be my better choice a turbo or supercharger and what would mount up easiest to this engine and space? i was thinking centrifugal supercharger but am still unsure?
    both are going to be good options. looking at a RSM kit for another 60* v6 with some modifications might be fun. but turbo will most likely give you the most bang for you buck as far as power. a few guys on here are turboed including myself... it all depends on what kinda power your looking for.
    if you do a search there are a few topics about the same question.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      i want torque more low end to be specific
        So you want uncontrollable wheel spin?
          If you want more low end torque, the worst possible choice is a centrifugal supercharger. Centrifugal superchargers only make maximum boost at redline and significantly less boost at lower RPM (roughly, boost = max boost * current RPM / Max RPM)
          You probably want a small turbo. The GT3071R or GT3076R should spool very quickly and be capable of over 400 horsepower.
          Tim
          325 whp 350 lb-ft
            i have not boosted mine but the car i bought used to be boosted at some point.
            this guy relocated the battery to the trunk to make room for the turbo and cut a hole in the bottom of the battery box to run the IC piping through.
            other than that he welded a couple brackets to the inside of the metal bumper.
            i have a ton of the project pics somewhere.
            i still have the IC and a few pipes btw. if you want them i could let you have them for $40 plus shipping.
            he also modified the intake manifold and the crossover coolant pipe. i have those too. $65 plus shipping
            lastly, he was using a 91-95 dohc and simply flipped the front manifold over and put it in the rear and fabbed a crossover pipe. i sold the pipe but still have the manifold. $25 plus shipping.
            if you want it all, i'll sell it all for $100 plus shipping. a decent start for a decent price i think.
              POST THEM!!! Itsa grand prix for once, i gotta see!!
