my upcomming boost project
  • my upcomming boost project
    i picked this up a while ago
    its an eaton m90 from a thunderbird supercoupe. i decided it was time for some boost.
    OOO, looks like this is going to be fun! Are you planning on doing a remote charger, or fabing a manifold?
      remote mounting it. it will go in front of the front valve cover, im going to move the rad forward. this way, i can keep it all under the hood.
        I saw a Thunderbird V6 with a pair of those into the low 12's.
          you dont need a pair to run 12s. a buddy of mine has a supercoupe thats over 400hp. he runs over 20psi with a ported m90. aparently if properly done, porting these blowers is worth 3 psi with a stock pulley.
            Sorry, it was 10's...http://www.toohighpsi.com/SCTC/sctc.htm
              Cool!!! Roots style blowers are fun since you get power right away.
                How to you remote mount a superchargher?
                  remote mount meaning its not mounted to the intake manifold. the t-bird charger feeds air in the back and up through the discharge hat and directs it through an intercooler.
                    hey sharkey tell me how u plan on doing that cuz come summer time i want 2 do the same. the only problen i am incountering is... how am i going 2 feed the belt so it will power my ps & ac. may be if i take off the idler pully that is directly under the ps. (at least i think its an idler, ill have 2 check on that.)
                    Cars beaten in 1/4 mile: 06 Honda Civic DX
                    love my 3400
                    check out my car at cardomain.com
                    search "alainman15"
                      The belt routing is going to be the least of your problems when retrofitting something like this on your motor. Please, don't take me wrong, but the fabrication it takes to remote mount a S/C, the pulley will be a simple task.
                      My suggestion would be to mount the charger where you want and measure for a new belt, just my $.02
                        ya i guess but u have 2 start somewhere then firgue everything out as u go along. like sould i have the tb before or after the s/c. if i have it before i guees ill need a blow off valve or something simmilar. what do u guys think? what r u doing sharkey?
                        love my 3400
                        search "alainman15"
                          im running the tb after the supercharger. im going to run a bov. my accessories are set up a bit different than yours. im going to have the belt come off my alternator (its were your power steering is) and over the supercharger, then from the charger around to drive the water pump and down to the crank.
                            ya gues yours would be a little different since you have an 86,gen 1 motor (if i'm not mistanken) and i got a 91, gen II motor. i looked on car domain and saw a big diference between our cars. so ill probly be on my our for now.
                            ps. awsome car
                            love my 3400
                            search "alainman15"
                              thumbs up
                              sound good to me !
                              I am currently also in the proces of rebuild and installation
                              of a m90 sc. on my fiero.
                              the engine is a 3liter,bored 2.8 engine with forged cosworth pistons.
                              the supercharger will go where my aircopump used to be.
                              in order to do so...I needed to relocate my oilfilter though
                              MORE mORE...mORE please
                              nothing's impossible-it's just a mindset
