Turbo 2.8 MPFI Tuning
  • Turbo 2.8 MPFI Tuning
    I have a a 88 Beretta GT, 5speed trans. I am in the process of installing a turbo as a spring project. I am wondering which type of optins there are out there to tune my car. I have a friend with a Z24 cavy that is tuning with megasqurit, but he had to take out the coil packs and convert to a fiero distributor, intake, and TB. I am not interested building a hybrid motor at this time. I would like to keep my factory coil packs and possibly harness. On the other hand i have seen that people are using RRFPR's or FMU's. I have not had good luck with these with my honda in the past and I ended up going to stand-alone in the end. I would just like to know all of my reasonably prices options.
    88 Beretta GT
    2.8 5-Speed
    I think Ben here can burn you a chip. Also sinister performance aka gmtuners.com can do one too for you.
      how do i get in contqct with Ben? Thanks
      88 Beretta GT
      2.8 5-Speed
        Either the link to the store above or by his screen name : SappySE107
          If you are looking to tune yourself, Moates.net has the equipment you will need. What ECM do you have? I didn't see where you listed the year of your Berreta, but the last 3 numbers on your ECM probably will be 730 for a MAP system and 302 for a MAF.
            I'm not sure at the moment what the stock ecu code is. but its a 88 Beretta GT. Is the tunerpro software any good? It sounds like a sister program to my turboedit i use on my CRX
            88 Beretta GT
            2.8 5-Speed
              Lots of guys use it on thirdgen.org, but I don't have any experience with it. 1988, you should have a MAF system (IIRC) and supposedly easier to tune than the MAP that I have.
                ya my car def. has MAF I remember dealing with it when I was building the air intake for it. A guy on another thread told me to use the #1227727 16197128 ecm out of a pontiac tgp. Is this a plug and play ecm swap. I'm not sure if you have to change other things or not with the harness
                88 Beretta GT
                2.8 5-Speed
                  He said you have to change the whole ECM, or just the memcal?
                    Why did your buddy go to a distributor? Is he running MS 1 or 2?
                    MS 2 should be able to run the DIS that 60º engines use.
                    Franz
                    1990 Z24-NA 3.1L
                    14.72 @ 92.24 MPH
                    14.89 @ 94.92 MPH
                    The boost is coming....
                      I believe he ran ms2
                      88 Beretta GT
                      2.8 5-Speed
