want to boost 1994 z24
  • want to boost 1994 z24
    i need to find someone who makes custom turbo headers, because i need one made, please help me out thanks
    The easiercheaper way to do it is re-route the y-pipe (at least on the RWD's) to the turbo, that way the stock manifolds can be used. Custom headers are expensive .
      the cavalier is fwd
        Originally posted by jaycutler2008 View Post
        the cavalier is fwd
        Yes, I know that! Just don't know how fesable it is on your car to use the y-pipe to turbo vs. headers. Also could consider a remote mount turbo. Are you using a single or twin turbos?
          if you want to keep the turbo under the hood, you can go to your local exhaust shop and have a custom y pipe made. you would simply have to buy a flange that matches your turbo and go the there. each exhaust pipe would exit the manifold and meet at your new flange somewhere over top of the transmission.
          88 Beretta GT
          2.8 5-Speed
