Test and Tune, (3-9-13)
  • Test and Tune, (3-9-13)
    http://www.youtube.com/watch?v=tVb6it6jGDM
    (3-9-2013) Beech Bend Park
    Non-intercooled MP90, 13-14 psi peak boost
    62-72 degrees F. (not really good air), Gas tank full, stock MAF, TCE 68mm TB, Racetronix pump, stock FPR, 36 lb injectors, 3-inch full exhaust, no resonator, 8.5x23 M&H slicks, custom trans, stock engine. Cooled down w/water prior to each run.
    12:53 PM
    Car#-----B888
    R/T------.127
    60'-----1.997
    330-----5.557
    1/8-----8.502
    MPH-----82.53
    1000----11.070
    1/4-----13.268
    MPH-----102.69
    Notes: w/Fram CA9778 air filter
    IAT: 117* start, 185* end
    ECT: 194-199*
    MAF: 10217 hz max
    KR: 4.8 max
    IDC: 83 max
    2:14 PM
    Car#-----B888
    R/T------.128
    60'-----2.175
    330-----5.709
    1/8-----8.628
    MPH-----83.46
    1000----11.189
    1/4-----13.363
    MPH-----103.52
    Notes: Removed air filter for remaining runs; Increased WOT timing 2*; Tried lower tire pressure, lighter burnout, to keep IAT lower; got wheel hop and spin, slight KR into 3rd gear.
    IAT: 86* start, 174* end
    ECT: 196-194*
    MAF: 10359 hz, 34.89 lb/min., max
    KR: 2.6 max
    IDC: 90 max
    3:26 PM
    Car#-----B888
    R/T------ .088
    60'-----1.956
    330-----5.443
    1/8-----8.355
    MPH-----84.49
    1000----10.902
    1/4-----13.078
    MPH-----103.63
    Notes: Quickest 1/4 run w/car to date.
    IAT: 104-178*
    ECT: 194-199*
    MAF: 10321/34.68
    KR: 3.6 max
    IDC: 91 max
    (4:33 PM) 13.312 @ 103.25, 1.998 60 ft. ....
    Notes: forgot "trac off" switch, run not scanned
    (Posted on all forums)
    Nice and consistent !
    Awesome job.
      A vid surfaced meanwhile, scroll to 9:55, set to HD, observe holeshot
      http://www.youtube.com/watch?v=U_pkQ6Z1cAw
        Impressive.
        Your slip with the 13.07 sure does match up with mine pretty close.
        1/4 mile best 11.59@119mph
        1/8 mile best 7.47@94.9Mph
          I could of sworn I wrote in here asking about your suspension set-up as you have a bit of sag on launch... Well I wrote it now lol
