went to the track
  • went to the track
    just thought id share this is my 1994 cutlass dohc w/ wai
    my times
    run 1
    reaction: .8363
    60ft: 2.3953
    330ft: 6.9299
    1/8 et: 10.632
    1/8 mph: 66.14
    1000 et: 13.7600
    1000 mph: 76.34
    1/4 et: 16.5253
    1/4 mph: 84.00
    lost by: .7846
    run 2
    reaction: .7049
    60ft: 2.4355
    330ft: 7.0245
    1/8 et: 10.7786
    1/8 mph: 65.59
    1000 et: 13.8989
    1000 mph: 76.03
    1/4 et: 16.7085
    1/4 mph: 80.56
    lost by: 2.2860
    run 3
    reaction: -.0018
    60ft: 2.4108
    330ft: 6.9457
    1/8 et: 10.6667
    1/8 mph: 66.24
    1000 et: 17.7700
    1000 mph: 76.48
    1/4 et: 16.5308
    1/4 mph: 84.13
    lost by: .4563
    run 4 (ran alone)
    reaction: .5022
    60ft: 2.4177
    330ft: 6.8791
    1/8 et: 10.5417
    1/8 mph: 67.31
    1000 et: 13.5829
    1000 mph: 78.02
    1/4 et: 16.2934
    1/4 mph: 85.96
    run 5
    reaction: .3632
    60ft: 2.4176
    330ft: 6.9944
    1/8 et: 10.7368
    1/8 mph: 65.84
    1000 et: 13.8566
    1000 mph: 76.08
    1/4 et: 16.6245
    1/4 mph: 84.21
    lost by: 1.0480
    run 6
    reaction: .2386
    60ft: 2.5209
    330ft: 7.1308
    1/8 et: 10.8854
    1/8 mph: 65.54
    1000 et: 14.0074
    1000 mph: 75.87
    1/4 et: 16.7812
    1/4 mph: 84.44
    lost by: 4.1452
    last run
    reaction: .2836
    60ft: 2.3828
    330ft: 6.9593
    1/8 et: 10.6892
    1/8 mph: 65.99
    1000 et: 13.7984
    1000 mph: 76.44
    1/4 et: 16.5584
    1/4 mph: 84.36
    won by: .1235
    yep...
      DOHC should run better than that. My stock 3100 cutlass ( when it was that ) could keep up with that.
      3400/Getrag 284 5spd
      350/NV3500 5spd
      2014 Chevrolet Malibu LS
        mine is a convertible and it was my first time ever to the track. look at the reaction times and 60fts that slowed me down some. im looking forward to getting back and trying again
          Convertible will slow you down quite a bit. They weigh a lot more than a normal W. Were you bringing the revs up when you launched, or going right from brake to gas? I know when I had an auto there was a certain point where if i reved it more on the line it slowed me down (probably around my stall speed).
            yeah i found that reving around 2k was good 2500 would spin plus i had bald tires and could barley launch
              i ran a 15.1 at 92 with my 95 lumina dohc with intake and exhaust
                Your 60fts are too high. You have to figure out your traction issue. Lower front tire psi and go a little softer off the line. You should be a mid to high 15 sec car. Thats 3100 teritory.
                02 GTP - 90* > Failboat
                www.blackbombshell95.com
                  well i had bald touring tires before that i could just roast even at the 23psi i was running and a shot suspension
                  i now have upgraded suspension and high performance tires. cant wait to get back but i cant afford too i can hardly pay for gas LOL
                    I managed a 16.0 @ 84.4mph with similar 60ft, so you must have been spinning. I did not spin but had a bad 60ft due to feathering it. Actually I had the best luck with traction with 40psi in the tires believe it or not with 205mm miss-matched all seasons.
                    So the times look about right, other than you are spinning which makes for the high time. This was with a stock 3100 at the time other than K&N drop in filter and a dynomax muffler.
                    One of your runs was almost 86mph, so if you had good traction that run you might have broke into the 15's.
                      With my 3400, my 60' times were just as bad and I was running ~16.0 @ 88-89mph.
                      I think my current bext 60' time was a 2.2.
                      350/NV3500 5spd
                        The best I could manage with my 95 grand prix 3100 was a 2.2 60ft running 16.2 in the 1/4. With a 55 hp shot I ran a 15.4. And a 75 shot I ran a 15.01.
                          oh and as for the times i forgot to mention im not your average 200lb guy
                            Not bad for your 1st time at the track. Its a fine art getting the launch just right. If it makes you feel any better DOHC's run mid 17's in colorado (5800ft Elev)! air is so thin here its sad... But makes me laugh when i still beet a Civic with a mear 17.5
                            A set of Good tires will go a long way. I ran a Odd ball size 235/55/16 for a while on my stock 16X7" wheel and really liked them. they hooked better and not so squishy on the sidewall like stock size.
                            S
                            Shane "RedZMonte"
                            1992 Lumina Z34-VIRGIN (RIP)
                            1992 L67 Lumina Z34 (SOLD)
                            1990 Turbo Grand Prix (SOLD)
                              went back ran a 15.9 with the new tires suspension exhaust and intake
