1st night at track
  • 1st night at track
    this was my first run of the night, also the slowest but my only win lol 17.704@77.25mph
    2nd run a little faster but lost by quite a bit 17.677@76.63mph
    last run, i was supposed to run vs my friends GST but some asshole cut infront so ended up lining up wita a mach one which you could see i got ate up and spit back out... although it was my best e/t...17.534@77.96 he ran a 13.860@100.47mph
    i got to work on my lauch and r/t though any suggestions????
    97 cutlass supreme
    3100 sfi
    cai
    ud pulley
    pu dogbones
    #14 rapidfires
    magnacore wires
    That one mustang ran a 17? lol was it a v6?
    Man you have a high 1/4! I cant read the slips really so not sure on your rt/60ft time. I would suggest a new oxygen sensor (denso, check out sparkplugs.com) if you haven't put one on. Is your CAI a true CAI? or sucking hot engine air? Not familair with rapid fires but if its a single platnium tip then it's likely hurting your spark performance. I run the normal old school Ac delcos and they are great. Some of those multi prong sparkplugs are just gimmick. Exhaust work would help you, new down pipe/etc back is best but a high flow cat, no resonator and straight through muffler on back would be good. Manderl bent 2.25" or 2.5". I noticed a difference just eliminating the resonator and stock muffler and I'm still running stock 200k cat and 2" factory pipe.
      put the stock parts back on and get back into the high 16's
      Brian
      3400 SFI V6, 4T60e
        i figured out what killed me, bad spark plug wire i was running on 5 cylinders, i started pulling them the #3 cylinders was off the wire was cracked oh and that mustang ran a 17 cause he was riding dirty on 20s lol
        97 cutlass supreme
        3100 sfi
        cai
        ud pulley
        pu dogbones
        #14 rapidfires
        magnacore wires
          i was about to say i think a 3100 should run better then high 17's my gp was stock and had a sticky thermostat and was running at 220 the whole time i was at the track and it was running mid 16's with heavy ass wheels
          1997 Chevrolet Camaro 30th Anniversary 5Speed.
          3800 V6 (i know its not a 60degree)
          stock for now
          1993 Special Edtion/GTP
          3.4 DOHC V6 LQ1 SOLD!
          CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
          180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
          VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
            yup that was the problem for sure...i replaced the wires and cleaned the spark plugs... ran a again and ran a best time of 16.561 @ 82.1 mph
            97 cutlass supreme
            3100 sfi
            cai
            ud pulley
            pu dogbones
            #14 rapidfires
            magnacore wires
              i havent ran my car with the 180 stat,chip,exhaust,cia,wire,plugs.... i really want to but i live in MI and everyday the track has been open for test n tune it has was snowing so they didnt run !!! onl yin MI will it be 70 in apirl one day and then snow the next! im looking to at leat hit a high 15 low 16 i think it might be a little better seeing the engine was running so hot last time i think that was the main problem for my slow times
              stock for now
