what gauge is factory battery wire ?
  • what gauge is factory battery wire ?
    i want to relocate my battery to my trunk, and id like to go 0 or 2 gauge
    and im pretty cheap, so iw as thinking of getting a bunch of junk yard battery cables and then doing a good proper solder job to join them together
    am i looking for trouble lol :P ?
    welding wire is like $1 a foot. Can't get much cheaper than that. I don't remember what I bought, but the cable is like 1/2" in diameter.
    You don't *need* to run a negative wire, but it's recommended.
    Okay now, that's enough of that.
      welding wire... good idea thats like 0 gauge prolly
      ill have to check out princess auto, they should sell that
      thanks
        for $43 summit racing sells the kit with cables and box.
        advance carries 2 gauge in bulk. welding cable is probably the cheapest. i'd not do the junkyard cables/solder method, too much to go wrong.
          The good thing about welding cable is that it is rated to withstand abrasion, welding sparks, oil, etc... Its perfect for use in an automotive environment...
            i picked up a cheap 12 dollar box from an rv store, came with the strap too
              I have 2 boxes of 2/0 welding cable. Its a little huge but would never suffer from voltage drop. It has a VERY high strand count too. Very flexible.
                well..... My PA is a 0 gauge, and I know that a battery cable is thicker than that!!!!! Is a battery cable a 00 gauge?
                LOL
                I know that the gauges are different. But the welding cable is a good idea
                Taylor
                1998 Lincoln Mark VIII
                  *remembers he has a princess auto catalog*
                  dang... 3.50 Cad a foot for 2/0 1248 strands
                  ..........1.89 Cad a foot for 2 625 strands
                  hmmmm.... maybe..... i ... should ... take the 2/0 get 20 feet, label it as 2 and say i only get 15 feet lmfao
                  that would be me saving $41.65 , for a total of $28.35
