NEED: Auto Dimming Mirror Wiring diagram
  • NEED: Auto Dimming Mirror Wiring diagram
    got a factory auto dim mirror w/compass from a 1996 Buick Park Ave. i'm putting it into my achieva and need to figure out the harness. it has 5 wires.
    1)pink w/black stripe
    2)black w/ white stripe
    3)green
    4)grey
    5)orange
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
    RE: NEED: Auto Dimming Mirror Wiring diagram
    does it have maplights? which model is it (pics?) I might be able to dig a diagram up
    Brian
    3400 SFI V6, 4T60e
      no maplights. GNTX-120?
      K&N cylinder filter
      Front STB
        does it have a little clear square button on the bottom, to turn the dimming function on?
        Green is definetly reverse-gear input
        black is def ground
        orange is usually the battery power for the dome lights (tis why I ask if it had reading lamps)
        pnk/blk is usually hot in run (battery)
        Grey- no idea
        is it 1 plug on the harness or 2?
        Brian
        3400 SFI V6, 4T60e
          there's a black 3-position switch under mirror. kinda looks like this;
          Off < M > C/M.
          other #s on back side of housing are;12055M, I-E13-012580, I-e13-02-6022, GNTX-120, and a bunch of patent #s
          BTW, has one 7 pin harness connector.
          There appears to be either a reset button or a zone button (for the compass) inside the housing beside the "off" side of the switch.
          K&N cylinder filter
          Front STB
            any idea?
            K&N cylinder filter
            Front STB
              I'm due to be at work tuesday, I'll try and print up the wire diagram.
              Brian
              3400 SFI V6, 4T60e
                i'm gonna try hooking up pink as key-on power, black as ground, and green as reverse signal. hopefully that will work. i saw a site that discussed the mirrors and apparently some mirrors are set up to dim outside mirrors simultaneously. so the two extra wires may be for outside positive and ground.
                K&N cylinder filter
                Front STB
                  I have the same Mirror and I ALSO need the wiring Diagram.
                  I did find out that the photo sensor on the back of the mirror dims YOUR headlights when meeting traffic
                  1991 Grand Prix STE
                  3.4 DOHC
                  1 of 792 Produced
                  Extensive Mods Done
                  1991 Lumina Z34
                  3.4 DOHC
                  Getrag 284 5spd
                  1 of 30
                    Interesting. Since I've removed my tint on the back glass (peeling) this would be nice to have. And my mirror is starting to oxidize too.
                      I was wondering how I missed this thread, and then I realized that until today, the last post was in 2004....
                        LOL I didn't even see that... Maybe someone has the solution by now??
                          id like to know as well, i just nabbed one of these outa a park avenue
                          2012 Chevy Sonic Turbo 6spd
