Aggggghhhhh
  • Aggggghhhhh
    So, my 3100sfi 2003 Malibu has always seemed to run a little hot to me (200-220ish according to factory gauge) but it has never overheated. Well yesterday while I had it idling in my driveway while I was recharging the AC I started smelling coolant. Checked gauge and it was peaked out at 260 and that little red light was on. I shut it off and let it sit. This morning on the way to work if I had to stop for any reason the temp would climb at an alarming rate. The check engine light is on, and I used twice the amount of fuel as I normally do.
    I'm not feeling good about this. And what sucks is this weekend me and the wife are supposed to drive down to Dallas and have a getaway for our anniversary.
    Oh, not to mention this is my only mode of transportation since her Toyota Sienna decided to break a timing belt or something 2 weeks ago. Just waiting on the timing kit for that.
    Any input or ideas would be greatly appreciated. I am going straight from work to advanced auto and having them pull codes for the CEL, and buying a new thermostat. I fear the one in the car is bad.
    Before I start the car this afternoon I am going to check the oil and make sure it doesn't have fuel in it. I'm afraid a HG took a shit on me.
    Sent from my iPhone using Tapatalk
    Why didnt you check the coolant? Pop the oil fill cap and look in there? Look on the dipstick?
      Cuz I haven't had my meds in a week or so and I was ready to take a fucking sledge to the whole car. So I walked away. After it cooled down the reservoir was at correct level. I didn't go any further than that.
        Must have been some trickery yesterday. I'm guessing I had too much water in the mixture and it evaporated because I just put in some 50/50 pre-diluted and it sucked down half a gallon before the reservoir was full and now she sits patiently around 180.
        But I had them run a code scan and it is throwing a crankshaft position sensor code. But the car is running fine
          Pop the oil fill cap and look in there. Look on the dipstick.
          Remove sensor, inspect it for milkshake like substance.
            could be pulley crank position sensor... It will still run without it but not to its full potential timing wise at least.
              Could that be what is causing the "popping" noise coming from under the hood between 5000-5200 when I occasionally wind it out?
                on the OBD2 cars, is the 24X sensor used for anything other than low-speed operation? with the OBD1 stuff, it's only really used for scheduling more MAP reads to average out for a supposedly smoother idle(though on the F-body calibrations, it read it up to 2000RPM, rather than the ~1250 for the 3x00s)..... i think it's questionable how well it works.
                  Can't be doing much. There is no noticeable difference in driving the car. Only issue I've had or found is the popping sound between 5000-5200 when WOT.
                    How are you putting coolant into the motor? Are you filling it directly at the radiator. Have you pulled the radiator cap off to check the coolant level inside the radiator when the cars cold? That fluid is going somewhere if it's missing and hopefully not into your oil. You gotta check all of that.
                      A 2003 Malibu does not have a cap on the radiator... It's a pressurized overflow tank system.
                        Never new that, is that what you have also?
                          Yes
                            I think it evaporated because I put too much water. Oil was just changed last week and it still looks new. No milkshake in the valve cover. It's not overheating anymore. I need a new coolant tank, might look into a snazzy aluminum one.
                            Also the car never smokes and still makes good power so I don't think it's burning the coolant.
                            Also today I bought so A/C o-rings and freon and recharged the A/C. All is well, thank you for the input everyone.
                              Well hopefully it's nothing major.
