What is this guy telling me?
  • What is this guy telling me?
    Regarding an engine swap into an Opel (other members have swapped 60ºV6, so this is nothing new...)
    Originally posted by Red0ktober View Post
    ...So I'm opting for a plentiful GM 60º V6 and a ubiquitous T5 5-speed (I already have them).
    Originally posted by wrench459 View Post
    A word of warning with the 60.
    There banked injection and are getting long in the tooth.
    I would first remove the six pin connector.
    IIRC ohm the pink/black to each leg...light/green..light/blue.
    If they ohm out close to each other your golden.
    For what it's worth I had one just today.
    4.1 ohms on one bank..3.2 ohms on the other.
    Friggin shorted injector:banghead:
    I have a complete wrecked but still running and drivable '93 Cavalier Z24 with the Gen-II 3.1L 60ºV6. I'll try to remember to check the injectors at some point, but it does run great...
    The 93 3.1L is still banked.
    The kicker is the idle air control valve...it's a stepper.
    The density system uses the IAC as a virtual MAF.
    Go figure...
    Oh and it's multi-plexed with the EGR valve
    150k miles later and it all seems to work just fine. I'm not worried.
    I have to stick with the older engines because they use a stamped steel oil pan instead of the structural aluminum ones on the Gen-3+. No RWD pans available for the newer ones and they are much harder to modify.
    My job is to find out whats wrong with the system.
    Ok yours is working good for now. Good for you.
    When it goes down....
    Do you have something to suggest, other than the fact that a medium-high mileage and twenty year old engine might eventually develop problems?
    I've seen NEW vehicles being deliverer at the dealership
    with massive problems.
    Now your asking about 20 year old pita's?
    Do you know what the PCM connector was rated for?
    Connect at the factory 1
    Disconnect at the dealership for warranty work 2
    Three strikes your out most of the times.
    Yes you can get away with with it some of the times BUT not ALL of the times.
    IAC a virtual MAF? I think he forgot the give part of "puff, puff, give" and kept puffing.
      Go figure...
      At first I thought it might be prudent to check the impedance on the injectors, but at this point I was thinking
        Well checking an engine for shorted injectors does make sense to me, but I think half of what he told you he said while tripping balls or high as a kite.
        I mean, who wouldn't want a structural oil pan when modifying an engine for power? If he means its too hard to tap for an oil return I don't believe it is.
        And the PCM connectors... If they were that bad at maintaining a connection after being reconnected 2-3 times I don't think there is a car out there that would make it out of the warranty period without a harness swap.
          Yeah, just some guy that believes he knows more than he really does.
          It seems he's under the misconception that batch fire (The genII 3.1 is really batch fire and not "bank to bank"), is somehow a problem, or maybe inferior to SFI which is definitely not the case.
          I don't understand the IAC as virtual MAF, he must not understand the function of an IAC (which MAF systems still had) or what a MAF does, and they do two very different things.
          Also what's multiplexed with the EGR? If he's talking ECM control of the EGR, it has it's own drivers and control lines.
          I have yet to find any OEM connector that fails after being disconnected and re-connected 3 times. I've have my ECMs unplugged dozens of times each, without any issue.
          It's just some guy trying to sound smart, but making himself out to be quite the opposite.
            I said that bit. I would like to use a Gen-3/4 block, I have an LX9 that I would love to use for something. I boxed the aluminum FWD pan to go over the Opel crossmember, it still doesn't fit as nearly as nicely as a RWD steel pan though. And my RWD motor mount options are reduced as well. I can't modify the crossmember much because of the transverse leaf suspension. Since I have the Gen-2 already, I'm just going to use that with all the Trooper and Camaro RWD parts I have laying around.
              moar below.
              moar below.
              and it seems most of the questions were already answered.....
              anyways, "IAC as virtual MAF", i can see where this thought comes from. the hybrid alpha-n idle used with the MPFI V6 calibrations could be described that way, since IAC position and learned IAC minimum position are a LARGE factor in determining fueling IF THE FLAG IS ENABLED AND SCALARS ALLOW IT. literally the first thing i disable in every 60V6 calibration, otherwise weird fueling inconsistencies pop up. i also removed the possibility entirely with nAst1, that is how much i dislike it.
              no 60V6 was ever operated in bank mode unless you count the TBI setups(i think), but those are certainly not the topic here. most are wired to appear as such if you don't know that 7727/7730 and their descendants use a single driver that shares load across two pins.
              i don't even know what is being implied with EGR.
              i've connected and disconnected the 7727 style PCMs many times without issue. dozens would also apply to me as well.
              he knows something, but his wires seem to be crossed about certain aspects.
                Drunk, high or tremendously misinformed... pick 2.
