calling all top 1% mechanics
  • calling all top 1% mechanics
    2005 Dodge Stratus 2.4L Vin X
    P0344 code originally, intermittent cam sensor. Placed on labscope, good crank signal, bad cam signal. Tested wiring, replaced ecu, new head, timing belt, etc...
    Replaced magnet and got good cam signal. Won't run, it tries to start but nothing. unplug cam sensor and she fires up. Now got no codes, labscope shows good cam signal, good crank signal and in time when compared to known good labscope readout. Injector pulse alos scoped and out of time compared to known good labscope readout. Any ideas?
    sounds like a correlation issue. unplugged cam sensors are ignored by computer so car runs fine. Valve timing is prolly not far enough out to feel a miss, However out of synch signals from plugged in functioning cam sensors cause codes at the very very least. Guess which code it would be?
