Definately not a V motor... My Rebuild.
  • #16
    A few pics from my D5200 Haven't really been able to play with it much.
    • #17
      Finished up this past weekend...
      Once I got going I said to hell with painting it... I just want it built... LOL
      Home made ring grinder.
      Pistons all in
      Old crap
      New hot shit!
      Gotta have a sense of humor with all of this
      Damn the head torquing procedure is WEIRD!
      Other side
      As of Sunday at 2pm... Gotta finish up fixing a PC for a friend Monday, deliver it to Hull MA then work on the car this afternoon. Should be running Monday night!
      • #18
        Since no one has probably heard this car before here is a quick start up vid... someone was asking how quickly my oil pressure light shuts off during start up so I made this recording... I should get a walk around when it's warm so you guys can actually hear it.
        • #19
          Better Vid.
          And Engine bay all done
          • #20
            Sounds smooth and ready to go
            • #21
              Yup, and it would be going if it didn't decide to crack its radiator... LOL. Ordered one monday hope to have it soon. Two small age/stress cracks on the top plastic tank.
              • #22
                Got it dyno tuned this last weekend 255whp/321wtq... I'm happy.
                • #23
                  So how many miles for your break in period for that motor ? Have a 2009 Forester here that is getting rebuilt because it was ran with very low oil level And great numbers !!! I would be happy too
                  • #24
                    I did 300 miles, then changed the oil then did another 1500 and change it again... I've been on that oil since and I kept it out of extended boost till I was over that 1800 total miles and had good synthetic in there... in that first 300 Yes I did hit some boost around 5-10 psi during normal driving and I hit peak a few times. Many say to keep it out of peak but I still feel if you are overly babying a break in then you really never seat the rings well, I agree to keep it out of extended periods of peak boost though because that can be a bit rough on it.
                    • #25
                      Jon did you use a high zinc break-in oil ? And this is a non turbo 2.5 And the g/f will be driving it when its finally finished at the machine shop I got word Friday that no1 crank journal was spun and started to push the bearing out of the cap !!!
                      • #26
                        Yikes... And no I did not use a high zinc... no one suggested it and the lifters/cams didn't change. I just used a conventional oil the first 1800 miles... Just swapped to Rotela T6 this last time.
                        • #27
                          ok thank you The rest of the motor is fine. Just got off the phone with the shop
                          Owner is a good friend and going to Line bore it and replace the crank for $450
                          • #28
                            Pics because it did happen... LOL
                            Pic of First and second run... that's just insane he gained that much that quickly!
                            Excuse the stupid auto focus...
                            This one was on manual focus.
                            • #29
                              loving the plates! what were the numbers? I can't read them easily
                              • #30
                                Wow I didn't post it, it's in my signature but my tune was 219/275 he got it to 255/310 after leaning it out and messing with the timing a bit.
