Screwed
  • Screwed
    I don't think this is normal...
    Used tires are normally reasonably priced :/
    But yeah, they won't patch that, and I don't suggest you do it either.
      duct tape it from the inside and good to go.
        Seems like someone trying to screw your tires. Replacement I guess!
        Gaskets | Cut Gaskets
          Lucky me for a change. Screw was only 3/4" long. Barely pierced inside. Patched and ready to go to the the Air Force Museum. 20 bux...
            They patched it huh? It must not have been discount. They used to do to the outside of the tread, now they won't touch anything in the outside 1/2" of the tread or sidewalls. So it must not have gone through the belts and into the inner layer of rubber. Good deal
