Turbo project almost done
  • Turbo project almost done
    1996 Grand Prix SE 3100v6 Turbo T04E .50 trim, intercooled.
    6-8 psig boost, 36 lb/hr inj, custom cross-over, cat delete, valve train cleaned well.
    24k BTU trans cooling, ported 52mm TB (equivilant to 58mm now)
    Cherry bombs with flowmaster 40's
    Gasket matched the LIM to Heads and the UIM to LIM (tapered the grind 1.5" in)
    3400 Top Swap (oops, not yet but soon)
    Boost/Vac, Trans Temp, Oil Temp, Oil Press, WBO2 gauges
    All engine bay exhaust heat wrapped, turbo blanket
    HP Tuner Standard
    New Cyl. Heads, new radiator, new water pump, new ignition coils/wires/plugs
    New hoses, new head and LIM bolts (torqued well), HD Felpro head gaskets, modified metal LIM gaskets, new exhaust gaskets/bolts, new NBO2, new CAM/CRANK sensors, new TPS, MAF Cleaned, Fully enclosed batt trunk reloc kit, new vacuum hose kit (all blue to match) w/ connector kit. I may have forgotten a few things.
    I got nearly everything done now.
    Only thing I am waiting on is a turbo oil feed flange. The previous one I had snapped when tightening the braided line to it. Cheap aluminum product. Although, I do believe I over tightened.
    Well, I still have to secure the gauges to the dash and steering column. But they are wired in and the wires are tucked away nicely. I had drilled a few discreet holes so the wires aren't exposed much. They enter the engine bay up behind and above the pedals, out of view.
    I tapped the ignition wire from the PCM leading to the MAF Sensor (pink wire). It should work well for switched power.
    The battery, I rerouted through the rear cab. The cable was placed under the seats and enter the trunk under the little trunk access/arm rest. This was to keep it away from the gas tank and rear tires, also to help protect the cable. It can't be seen in the cabin, nice.
    I want to start it up so badly but I am waiting for the oil feed flange. I refuse to spin up the turbo w/o oil feed, even at idle.
    Tomorrow I plan a picture day. I doubt the flange will arrive tomorrow. Probably by friday at the earliest. Darn Flat Rate Shipping USPS. I should have over nighted it. Oh well. The spare time will allow me to triple check everything.
    Once the car runs, I plan to move it to my new garage where I can finish the exhaust under the body. So, yeah, I'm not done yet. But the hardest parts are over with. Welding up an exhaust under body is a cake walk compared to fitting/welding the cross-over and downpipe in the engine bay with what space I had to work with. There is enough room for the 2.5" pipe, but only that. All the bends had to be cut just right, no room for errors beyond 2-4 degrees.
    I still have to build a new windshield wiper fluid container to fit. But that is also easy work. Cutting, forming and bonding plastic is much easier on the hands then steel. Though, I still am going to try searching out a container from another vehicle model that may fit. Anything at half size might work with some minor modification.
    I also plan to use the A/C pressure sensor to wire the WBO2 sensor into the PCM for data logging, since I had to remove parts of the A/C system, it will be useless otherwise.
    I wonder if there is a way to control the EGR valve as a turbo timer. Similar to a SC timer. When the boost has been pushed long enough, safely, the EGR could open and vent the exhaust pressure to the atmosphere. Allowing the car to remain in WOT but disable boost.
    Soon, I will be starting the long road of tuning her up. Small steps and lots of research before I make any changes. I've read several tuning guides through and through many times. I am considering a 2-bar SD operating system. It would be nice to be able to measure the boost through the PCM and have it react accordingly with fuel adjustments. But, I have time to make that choice yet.
    And when all is done, by spring time, I am going to give her a world class paint job. Step by step, bit by bit. One day, she will be done and riding/looking smooth as ever.
    if you go WOT with a turbo and the EGR is open to the atmo, it's essentially a wastegate. you could probably add a rocker to the power/ground and force it open...
      As of April 2
      Engine: 2006 SV6 3500 LX9
      Trans: 2002 Getrag F23 5speed
      Injectors: #36 GTPs
      TB: 65mm TCE
      Maf: 1999 3400 Montana.
      Beverages: Ice Cold CANADIAN.
        Originally posted by planethax View Post
        I get the point, lol.
        I will definately get some pics up today. I will shoot at all angles. Maybe a scrolling video as well.
        I have been telling myself, "Must get pics, must get pics" but I have been so busy.
        I will be at the garage around 4pm EST. By 5-6pm I'll have the pics up.
          I was thinking about a switched timer. When the throttle is WOT, the switch is triggered and so many seconds later, 20-40 seconds, the voltage to open the EGR is pushed. After the WOT trigger is released, the EGR is closed if it was opened.
          I'm going to have to build the circuit myself, but a simple timer circuit isn't hard. I need two, one for the EGR open and one for the EGR reset for cool down and a trigger commonly used for WOT NOS switching.
          Essentially, I will have the benefit of WOT w/o having to worry about overheating the turbo.
          But that project is down the road. I have to build it on paper first, collect the parts, build and test first. If it works well, I'll definately share the knowledge.
          And yes, PICS PICS PICS are coming!!!!! hahaha.
            Speaking of timer, the clock is ticking, dude. You only have a few more hours to satisfy our pic craving.
              Up to date pictures. Not complete but enough to satisfy, lol. She is a dirty car right now. In spring she will have body work done and painted. Along with some cab work, like dash vinyl paint, seat covers, re-carpet, ect.
              Keep in mind, the body is older then the engine. 108k/58k miles respectively. Though, there is no serious issues and will be cleaned up this spring. I don't like showing off a dirty car, but I'm sure most of you guys can see past the grim and see potential when finished.
              I need to grind off about 1/4" off the right engine mount. The Boost Controller and heater hose sit over the mount. after the small grind, it will fit with a little room to spare, avoiding damage to parts over time. I keep forgeting some of the little details, but will surely get done before I turn the key.
              Still using 3100 UIM, LIM until I get the new 3400 top swap and paint them
              Engine Front
              Engine Side
              Dash
              I want to get vinyl paint and do a black match to gauges. Getting Wheel Cover, later.
              Trans Cooler
              Trans Cooler 2
              Intercooler
              Oil Return
              Downpipe
              What I have to shovel when I get it running
                Engine bay looks very busy.
                You may want to move the Maf a little further away from TB.
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                  The engine bay is busy, lol. But everything has wiggle room. Other then tie up some vac lines and wires, not much more I can do. As long as everything is secured, protected and functional, it won't matter when the hood is closed and she spools up with that turbo scream pulling the passanger and driver into their seats.
                  I thought about that. I will be watching the MAF functioning with HP Scanner and if I see any issues, I'll move it back. But the worst I see is a skewed signal when the TB plate is closed from wot. Decel AFR settings should aid in resolving that. But if it gets to be an issue, I will move it.
                  Just a few small items to take care of.....
