200HP Space Heater
  • 200HP Space Heater
    I'm probably the last person to think of this, but...
    Trooper with 3" exhaust + 3" clothes drier ducting.
    I wouldn't trust that.
      that is just venting to the outdoors, right?
        That only works if the vehicle is out side and you are pumping the hot exhaust into the garage.
          Yeah? It's a real snug fit on the exhaust pipe, and with a hose clamp. The flex connects to a straight piece that goes a couple feet past the garage door. I let the truck warm up in the garage, then I adjusted the timing. It didn't smell of exhaust at all, nor did I die.
          I was joking about using it as a space heater, that's just silly. Also unlikely that it makes 200hp. :/
