SEMA TT 3600 Camaro
  • #16
    • #17
      i want that intake manifold setup.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • #18
        well for an NA car it would be even worse than the one on the 3400 ATM because it has long long long runners because that still bolts down to the LIM that the 3600 has.
        • #19
          <- Gets ideas for the Mustang...
          • #20
            well i meant ideas for a custom one. something along the lines of that one but with a supercharger feeding it.
            99 Grand Am GT
            • #21
              i'm trying to remember how large the engine bay is for a mustang of that vintage.... obviously a 5.0F fits in there easily, so i'm sure there is enough room to probably replicate this exactly if you wanted to...
              • #22
                There is that much...
                • #23
                  CSC on a 5.0...
                  i'd say depending on your radiator/fan combo and how far back the 660 sits, you could probably pull off the showcar setup with no problem at all...
                  • #24
                    i might buy a 91 mustang GT White/black inside, black outside, exhaust, cammed, cold air intake, 5 spd... PERFECT body shape!
                    $300.
                    • #25
                      FYI but a 460 will fit. Biggest problem is getting headers to fit around the strut towers.
                      Your local OBDII moderator
                      2000 Grand Am GT w/ WOT parts
                      • #26
                        my dad's 83 vert has small tube headers....
                        • #27
                          :drool:
                          • #28
                            Twins for 7 psi??? A single with an IC would have gotten 450 HP, although im pretty sure GMPP knew that, and at 7 psi, the air isnt very hot... Its a very, very, clean car nonetheless. Thumbs up for GMPP
                            Originally posted by Mars
                            Haha ^ Wrong Wheel Drive.
                            No 60ºV6 at the moment
                            • #29
                              personally, i'd run an IC anytime above 5psi, but that's how i am, and it wouldn't be 5psi for very long either...
                              • #30
                                LOL I completely agree. When I start project "2800" it will definitely be intercooled. Ill also be making a manifold similar to the TT camaro's.
