Needing head help
  • Needing head help
    Hey guy and gals.I'm new here and I need some help. I have a 1994 firebird witha 3.4 liter engine. I have been reading and was wanting some info.on the aluminum cylinder head swaps. i have found 2.8 and 3.1 canted valves and d-shaped combustion chamber which promote swirl in the cylinders. So my question is which year heads can i use and will it work with my stock intake manifold. I'm really want to use these type of heads if possible. i have went to the gm dealer and they cant help me. i have caseing numbers for different type and i have part numbers as well. so if anyone out ther can help plzzz do.
    thanks your friend Doug.
    They will bolt to the engine but not too the intake. You have to do an entire top end swap. Check the engine swap section and the pushrod performance section
