Delta Cams
  • Delta Cams
    Has anyone had experience with Delta Cams? From what I've heard, they came make exact copies of crane cams for a much cheaper price.
    They are only slightly less then GM for the same cams.
    I got a 262 modified for boost from them. Reground it was short money, but they said they can't regrind a roller lifter cam, and that was the biggest I could go with a re-grind.
    GM sells the 260 (262 whatever)advertised for just over $125 with lifters. It's actually a 212*/212* and .440/.440 lift.
      they re-ground my roller cam in the 3500 for a very good price, great guys to deal with.
      If you have them doing something custom, make sure they call you with the final specs before they grind it. They fudged my lift numbers a little and caused me to get a little too much valve overlap. Still performs very well though...
        I've heard troublesum things about them. IIRC they are located like 15 minutes away from my home. In Tacoma, WA
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
