NGK - iridiums
  • NGK - iridiums
    Anybody ran these?
    I'm thinking of trying
    them out on one of my
    motorcycles. I'm running
    big jets and clean too
    often. Also thinking about
    the ek's
    You mean you clean your plugs due to fueling? If so iridiums will be of no help. What you might try doing is stepping up the heat range.
      Yes.
      And I actually went down one
      from cr9 to cr8 a few years ago
      - kawasaki recommends going up or down
      by one so I do want to stick
      with that if damage would occur
      by going any lower.
      the bike runs strong with clean plugs
      no popping out the pipe or carbs so
      mixture settings are fine. Could go one
      or two lower on the mains or just gotta
      get a hotter spark happening here.
        Well if you go up a heat range the plugs will run hotter and help burn off fuel deposits. If you try them and run into any spark knock then just go back down a range and try a different approach. Is this a 2 stroke motor?
        Plugs are really never a solution for over fueling. Maybe you should lean it out a bit. Too much fuel kills power just as equally as too little fuel.
          It's an '89 ZX10
          Hooked up with an ebayer
          today who's local and distributes
          ngk, K&N, fram - all bike stuff
          no autos. Anyway, we talked
          for a while and he sold me
          on the idea of going to 7's,
          actually wanted to sell me
          iridiums and explained how
          they worked better over the
          regular one's but I passed for now
          since I'm still working out the
          right heat range.
          Because I really don't
          push the bike hard, he said
          there shouldn't be a concern
          for frying piston's. So 7's are
          in with a half turn out on the
          screws. It's a tad softer on the
          low end but not boggy so I hope
          that's enough to where I don't
          have to run smaller mains.
          I'll pull the plugs in a day or two
          and see if 7's do the trick.
          Thanks for your input dude!
