seat removal
  • seat removal
    Can anyone tell me what size socket I need to remove the seats in a '97 Lumina? It's that star shaped almost reverse-torx looking bolt. Thanks.
    you can buy a reverse torx for it. I have one.
    When I can't find mine, I just use an 8mm socket. It works fine as long as they are not seized.
    I think the reverse torx is also an 8mm.
    Taylor
    1998 Lincoln Mark VIII
      8mm is what I use.
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
        Ha. It IS called a reverse torx then. That's what I was guessing (I had never seen one before). Thanks for the info. I didn't want to eyeball it and end up with the wrong socket.
