Just great... Another new 60ºV6
  • Just great... Another new 60ºV6
    Yep, that's right. GM has announced yet another new 60ºV6, although this one is slightly different...
    Originally posted by GM Media
    Cadillac to Debut GM's Powerful New V-6 Clean Diesel
    • GM’s first production application of innovative, closed-loop combustion technology
    • Cadillac CTS adds engine to its portfolio in 2009
    • Low emissions, high performance and excellent fuel economy
    • 184 kW/250 hp, 550 Nm (406 lb.-ft.) torque, 2.9-liter displacement
    • Compact design enables transverse and longitudinal installation
    Geneva – General Motors Corp. unveiled a new 2.9-liter V-6 turbo-diesel engine that features state-of-the-art injection and combustion technology for minimum emissions and maximum performance.
    The new engine (184 kW/250 hp) will be mainly sold in Europe and makes its debut at the Geneva Motor Show (March 8-1. Its first production application is scheduled for 2009 in the new Cadillac CTS.
    “We expect the V-6 diesel to be highly competitive in the European luxury segment,” said Jim Taylor, Cadillac General Manager. “With its excellent low-end torque and its high power output, it is a great fit with Cadillac’s performance-oriented brand character.”
    The compact dual overhead cam, four-valve V-6 engine belongs to a new GM family of diesel engines, featuring an innovative closed-loop combustion control system designed to meet future emissions standards. The engine can be installed in a longitudinal or transverse layout and can be adapted to a wide range of two- or four-wheel drive vehicles.
    GM’s development of the new engine is being coordinated under the leadership of GM Powertrain’s European operations in Turin, Italy, in cooperation with VM Motori based in Cento, Italy. GM Powertrain will focus on the development of the clean combustion process, electronic engine control and exhaust-gas after treatment, as well as calibration and integration into GM vehicles. VM Motori will build the new unit at its plant in Cento, Italy, and is responsible for the mechanical aspects of the engine’s design, development and bench testing.
    “The V-6 diesel integrates leading technologies and will deliver outstanding performance, fuel economy and low emissions,” said Roger Johansson, GM Powertain Europe vice president.
    The V-6 engine management system enables optimal fuel economy as well as reduced emissions and noise by using a recently developed combustion control technology. Key enablers for the system are high speed piezo-resistive cylinder pressure sensors that are integrated within the engine glow-plugs. These specialized sensors acquire real-time data from the combustion process, enabling instantaneous fine-tuning of the fuel injection process. In the future, this clean combustion control technology will be introduced in other GM Powertrain diesel engines.
    The high-pressure, common-rail system provides up to 2000 bar (29,000 psi) injection pressure. The injectors are quick-firing piezo-electrically actuated, allowing up to eight injections per engine cycle. The after-treatment system includes an oxidation catalyst and a particulate filter that are close coupled to the engine to achieve future emissions standards.
    An electronically controlled variable geometry turbocharger generates boost pressure. The engine has a torque of 550 Nm (406 lb.-ft.) beginning at 2000 rpm, while providing effective fuel economy and reduced emissions.
    The new, compact V-6 powerhouse features aluminum cylinder heads and a 60 degree bank angle, 83.0 mm bore and 90.4 mm stroke, which results in displacement of 2935 cubic centimeters. The engine block is made of stronger and lighter Compacted Graphite Iron (as compared to lower strength aluminum or heavier grey cast iron) to optimize engine packaging, weight, refinement and performance.
    http://media.gm.com/servlet/GatewayS...37&docid=33949
    i bet with a nice turbo u could make some retarded torque out of that thing
      Now josh can swap that into his VW and make it a 60V6
        Its already slightly retarded at 406 foot pounds from a 2.9. I want to know what transmission is going on it.
          That thing has more torque than the 350 in my tahoe and almost as much hp. That is impressive.
          1994 Cutlass Supreme Convertible 3.4 DOHC
          1969 Oldsmobile 442
          1997 Chevy Tahoe
          http://members.cardomain.com/mperkins442
            shall their be a 60v6 tahoe in my future
            1969 Oldsmobile 442
            1997 Chevy Tahoe
              wow, id like to see what tranny they are using as well, thats alot of torque to begin with, but its so easy to make big power with the desiels
              then again the tranny wont see high rpms, 4000 tops lol
                Awesome! I still have dreams of installing a turbo diesel in my Jimmy, this one just might be possible.
                This is the first line of the article
                  First to swap into a W-body wins!
                  I'm guessing they're using the 6L70-E, but beefed up. Maybe like a 6L70-E HD. Surely the LS2 six speed could handle it.
                  BTW, who else is appluading GMs placement of that alternator. Inaccessible parts FTW!!!
                    sorry i ment a bigger turbo
                      I didn't notice the alt location but that is just awesome.
                        Originally posted by OldSkoolGP View Post
                        First to swap into a N-body wins!
                        fixed.
                          First to swap it into anything gets a set of decals. GO GO GO!
                            First to buy me one, wins a pat on the back.
                            Then I'll drop it in the Regency. Talk about an L67 burn!
                              How much is that motor My 91 look like it should be blowing out black smoke anyway:P
