Am I Running Lean?
  • Am I Running Lean?
    ok so last weekend me and some friends went up to mountain for some canyon runs.. i was having a hard time keeping up with some of the cars because, well i had the pedal down all the way but i was accelerating really slow and once it got to like around 60 it seemed like it just stopped there but kept climing slower. are these signs of running lean what could i help to do fix this any suggestions?
    97 cutlass supreme
    3100 sfi
    cai
    ud pulley
    pu dogbones
    #14 rapidfires
    magnacore wires
    The only way to know for sure is to scan and record the LTFT and STFT values while driving. In order to do that you'll need a scanner or aeroforce gauge. Until then, everything is just speculation.
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
      would that be the same as af ratio gauge? or what scanner?
      97 cutlass supreme
      3100 sfi
      cai
      ud pulley
      pu dogbones
      #14 rapidfires
      magnacore wires
        Umm... no.
        Okay now, that's enough of that.
          that could be lean.. u should have checked ur plugs after.. if they were white it was lean, and black rich.. But usraly rich u get poping and backfiring outa the pipes.. and too lean u get babling from the manifold were it just dosent wanna rev higher.. the fact that it was slowly climbing in rpms is odd tho.. Iv heard that old EFI systems when u get up in the mountains and it leans out that if u shut it off for a couple min so when it re-fires the computer retests the atmispheric pressure telling it to pump in more gas.. that may be bullshit kuss some idiot told me that but its worth a shot nex time...
          Six-t-Six Motorsports
          2.8L Chevette Roadcar
          3.2L Acadian Racecar
            No. A A/F ratio gauge is just a feel good lie. Since it's using the signal feed from the stock narrow band oxygen sensor, it can't really read if its way lean or way rich. Instead you need to know what adjustments the PCM is making. The cheapest way to do that would be with an aeroforce gauge.
              Actually the cheapest way would be to take it to autozone and have them scan it for free....
                The Autozone scanner is for DTCs only. It won't scan PCM outputs like LTFT, STFT, MAP, MAF Hz, etc.
                  Going up a mountain...what elevation did you start at and how far up did you go? How many friends and how much gear?
                    If you could find a Tech 2 to look at your long term and short fuel trims you'd know 100% what is happening with the adjustments. You can also adjust them some if need be.
                      ok now i need info on that aerogauge... some one fill me in please
                      97 cutlass supreme
                      3100 sfi
                      cai
                      ud pulley
                      pu dogbones
                      #14 rapidfires
                      magnacore wires
                        well i was solo in my car but not much weight cause i took my speaker box out... i had it in d3 part of the time and tried it on D but same thing... i think the highest we got was 8000ft
                        97 cutlass supreme
                        3100 sfi
                        cai
                        ud pulley
                        pu dogbones
                        #14 rapidfires
                        magnacore wires
                          If anything, you would be running rich, as atmospheric density changes quite a bit every thousand feet, as you climbed, your computer would constantly be adjusting for the reduction in oxygen. try a 9.5% reduction in power at only 3000 feet from lack of oxygen. You, being over 7,000 feet...
                          Your 02 sensor would have noticed this lack of oxygen and cut back the fuel, resulting in a much less power-packed mixture. Fortunately there are products out there that are chemically bonded with 02 that you add to your fuel. How much you need you can figure out, but they'd help you get up the hill a little faster by adding oxygen to the mixture, which will ultimately let the computer add some more fuel.
                            Yup, ive done that, going from phoenix to flagstaff. Car felt like a yugo. Driving back down to the valley was quite an experience though:P Your computer reads baro on startup and unless you meet the conditions for it to update (WOT and maybe more variable?), it will use the O2 to correct for the incorrect factors. Gotta love closed loop.
                              Originally posted by IanSzgatti View Post
                              Fortunately there are products out there that are chemically bonded with 02 that you add to your fuel. How much you need you can figure out.
                              octane booster?
                              97 cutlass supreme
                              3100 sfi
                              cai
                              ud pulley
                              pu dogbones
                              #14 rapidfires
                              magnacore wires
