next chapter in the modifications...
  • next chapter in the modifications...
    Well, here's the newest thing i changed on the car.... A new set of 17x7 wheels and some 225/45ZR17 Goodyear Eagle F1 GS-D3 tires..
    As ya can see, i REALLY need some bigger brakes!
    Cliff Scott
    89 BerettaGT
    89 Volvo74]0
    Cliff Scott
    89 BerettaGT
    04 AleroGX
    Lookin good! Hard to believe those TINY brakes actually stop the car, isnt it?
      What do those wheels weigh?
        wheels are heavy! 24 pounds each (i brought one in the post office and weighed it!)
        But the wheels were REALLY cheap.... (the tires cost more!)
        Oh, and as for the brakes, ya, I think I'll probably get the BAER upgrade (i think it's 12" rotors?)
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
          You should get clear side markers. How much is the Baer setup? Sounds pricey!!!
            hmm... I'll have to think about clear sidemarkers.....
            The Baer setup is like 800 somethin per set (they make front and rear)... actually the kit is for the j-bodies but it should work all the same..
            Cliff Scott
            89 BerettaGT
            89 Volvo740
            Cliff Scott
            89 BerettaGT
            04 AleroGX
              wow, those brakes look insanely small behind those rims. What size they stock?
                i think pre 92 they were 9 inch, and 92+ are just shy of 10 inches.
                If I were you, i'd just conver to the caddy brakes, they're big, and alot more cost effective, and replacement bits will be cheaper as well.
                The difference between an individual terrorist and a government in some cases may be simply that the former has a bomb but doesn\'t have an air force.
                  Yeah, they're 9 and somethin inches.... The only thing that's of worse is that they were standard on the A-Body cars...
                  Cliff Scott
                  89 BerettaGT <-9" front brakes, rear drums..
                  89 Volvo740 <-11" discs all the way around!
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
                    Goddamn those wheels are freakin' sexy. I like the silver and black... I want some wheels like those. Too bad Berettas have different bolt patterns. =/ Goddamn 5X115 bolt pattern. I can't find any sexy 5 spokes for my car, well I kinda like the Voxx ERG's that they sell on www.discounttiredirect.com
                    What happened to that guy that did the 94+ brake conversion on his Z34? I heard he had the E-Brakes working.
                    --Rob
                      ok, now what will you say that those wheels will also bolt up to your lumina just fine =) well, they're 5x100 and 5x114.3 (does that .7mm make that big of a difference?)
                      dual-pattern under those centrecaps!
                      Cliff Scott
                      89 BerettaGT
                      89 Volvo740
                      Cliff Scott
                      89 BerettaGT
                      04 AleroGX
                        Ask Ben about putting 114.3mm wheels on a 115mm car!
                          I would poop myself if those wheels fit on my car... but I've heard of people having problems with 114.3mm wheels...
                          --Rob
                            Ya, i wasn't too concerned about whether or not it was 114.3 or 115, because, well, I only needed the 100mm set...
                            This is one of the next planned modifications...
                            that's a pic of my friend's FW, but i got the same one that's on it's way..
                            Cliff Scott
                            89 BerettaGT
                            89 Volvo740
                            Cliff Scott
                            89 BerettaGT
                            04 AleroGX
                              Fidanza flywheels kick ass. I just wush I had a use for one...
                              Looks like a pic of Geoff's.
                              14.60 @ 96.33 for now...
