Supercharged Alero
  • Supercharged Alero
    I didn't find Greg's thread so I am going to start a new one as a continuation of where he left off. The car is currently in a pop up garage for the winter so I only have this idle video for now. Car is running pretty decent, though I need to check for boost leaks since it doesn't go over 8 psi. Turned off the 24x sensor stuff in the computer to fix the random misfires. You MUST use an OEM crank pulley, as the aftermarket ones don't seem to work too well with that sensor. Anyway, more to come this spring. Removed the intercooler stuff and going to go with spraying meth/water to keep the temps down.
    I didn't even know that. Thanks for the tip!
      What does my alero have to do with your brother selling tires?
        Skipped Spring, right to winter?
          Didn't do much of anything to the car this year. I think I drove it around the block twice. Redid gaskets but that didn't really change anything:/
            Hopefully you have some time for it coming up then! Just glad this one is still in an enthusiast's hands
